H&R rear ARB level sensor bracket
foggy3061
VCDS User
So, I find myself in need of the H&R rear ARB level sensor bracket for an upcoming retrofit. Has anyone ever had any success in sourcing that single bracket alone…….if so who/where from?
Said bracket circles in the images below to show what I’m harping on about!
So, i think I've got the part number for the bracket I require.
Next question: Can anyone recommend a UK H&R dealer who can/has sourced spare parts for them?
I don't suppose you can get spare parts for H&R @CRS Performance?
Hi there , I have never sourced that bracket on its own , I have however modified plenty to take the Head light level sensor it isnt difficult
Do you have a Bracket for a Non LED /Zenon car ?? or is the bracket missing entirely
E C Parts are the importer for H&R and it might be a long shot that they could order specially for you ??
Yeah the van currently has non LED H&R ARBs hence a non level sensor bracket fitted.
Yvonne was good enough to provide me with the part number for it but actually ordering it is proving difficult so far! :confused:
if you get stuck ill make one for you , we just need your original bracket
Thanks for the offer but as the van is in use daily, if i can't easily get hold of the H&R bracket, I'll just have open up the OEM level sensor backet to fit over!
Hi there Yes i have done that before , the holes for the bolts need to be drilled out a bit and some of the bracket cut away , but the switch has no weight or stress so it will be fine
I’m in the same situation now, did you have to get these for the front as well?
No, the front level sensor is attached the front bolt of the front wishbone. You just need a new bolt (as it's a stretch bolt) and nut to mount the front sensor.
How did you get round the problem at the rear?Did you get a bracket from H&R?
Well I’ve cut the bracket to suit today but I’ve also emailed H&R to see if they’d supply me one.
I’ll let you know if I get any joy!:thumbsup:
Yeah I emailed H&R too and they were great with telling me the part number but said I'd need to buy via the UK dealer, which is Euro car parts.
I emailed Euro car parts and they cryptically said they don't stock it but if I was to contact my local branch they should be able to special order it for me. Currently ongoing! :rolleyes:
I think i should order several to keep in stock , there are so many people buying these bars and later transplanting them to newer vans with LED /Xenon lights
we are getting calls for the bushes as well so ill order stock on all the spare parts
image.jpgManaged to bend mine round after some cutting.
Got a reply from H&R.
This could help you @CRS Performance & @foggy3061
Thank you for your e-mail.
The bracket is available as a spare part with the part number: HR33-S065K01
As I doubt that any dealer will have this single part listed separately,
you can contact the specialist sales team of our UK importer Euro Car Parts
for ordering it:
specialistsales@eurocarparts.com
I am not sure if they have listed it separately as well but if you let them know that
you have been in contact with me already, they will be happy to help you getting this part.
Mit freundlichen Grüßen / best regards
Yvonne Menzebach
Export / Sales
Hi there , I am the H&R importer for South Africa and therefore i am quite friendly with Yvonne , she handles my account . Top lass very helpful and knowledgeable .
