Hi there , I have never sourced that bracket on its own , I have however modified plenty to take the Head light level sensor it isnt difficultI don't suppose you can get spare parts for H&R @CRS Performance?
Do you have a Bracket for a Non LED /Zenon car ?? or is the bracket missing entirely
E C Parts are the importer for H&R and it might be a long shot that they could order specially for you ??
if you get stuck ill make one for you , we just need your original bracket
Hi there Yes i have done that before , the holes for the bolts need to be drilled out a bit and some of the bracket cut away , but the switch has no weight or stress so it will be fineThanks for the offer but as the van is in use daily, if i can't easily get hold of the H&R bracket, I'll just have open up the OEM level sensor backet to fit over!
I’m in the same situation now, did you have to get these for the front as well?Yeah the van currently has non LED H&R ARBs hence a non level sensor bracket fitted.
Yvonne was good enough to provide me with the part number for it but actually ordering it is proving difficult so far!![]()
No, the front level sensor is attached the front bolt of the front wishbone. You just need a new bolt (as it's a stretch bolt) and nut to mount the front sensor.I’m in the same situation now, did you have to get these for the front as well?
You can modify the original bracket to fit over the H&R bracket , a bit of cutting and drilling needed thoughHow did you get round the problem at the rear?Did you get a bracket from H&R?
One more avenue to try and if not it's modify the oem bracket!How did you get round the problem at the rear?Did you get a bracket from H&R?
Well I’ve cut the bracket to suit today but I’ve also emailed H&R to see if they’d supply me one.One more avenue to try and if not it's modify the oem bracket!
Yeah I emailed H&R too and they were great with telling me the part number but said I'd need to buy via the UK dealer, which is Euro car parts.Well I’ve cut the bracket to suit today but I’ve also emailed H&R to see if they’d supply me one.
I’ll let you know if I get any joy!![]()
I think i should order several to keep in stock , there are so many people buying these bars and later transplanting them to newer vans with LED /Xenon lightsYeah I emailed H&R too and they were great with telling me the part number but said I'd need to buy via the UK dealer, which is Euro car parts.
I emailed Euro car parts and they cryptically said they don't stock it but if I was to contact my local branch they should be able to special order it for me. Currently ongoing!![]()
