I have thought about changing the top tray ,but I need to look at a caravelle and measure up .if you cut top tray out and it doesn't work it's new dash time .when I first saw the caravelle one I thought it was a straight swop ,but then when I got the hire van I realized it was moulded into the dash .It's on the list to look into as I hate that top tray ,by the way it has a 12 volt socket just like T5.1Calis and Vels seem to miss out on that middle storage "slot"(not the one by the gear shift), it is covered by a trim.
That is where I think it would be good if the top glove box used all of the space available for the top and middle storage. It would make the top glove box a bit deeper.
Has anyone looked at converting the standard dash top tray to one with a lid and a power point. The T5.1 tray hasa 12V socket that is always live and it is the one I always use.
Could you take a closer picture of the bottom please @BiTurbo every time I zoom in it it jumps back to small pic
If it is a different dash is there any difference in the shape at the A post plastics?Top tray won't fit. Its a totally different dash. Checked one out the other day.
Steady on...Nice one thanks mate
The 2nd usb goes above the 12V socket in the middle storage area, you prob dont get them on the low spec california![]()
No not touched the vent apart from removing the foam.@BiTurbo ,did you trim bottom of vent or recess it in to the dash .
How long did it take you ?
When I tried vent it wouldn't fit flush,even with foam removed ,perhaps once you cut the dash away for glove box it must fit .No not touched the vent apart from removing the foam.
It took me about 10hrs, painstaking it is.....
Are you getting the 3 other parts fitted now or do you need a rest
It looks better than I expected ,I thought that would be the line to cut along ,it doesn't look like it needs anything doing across the bottom .well done ,I know it's going to be a right job .But I can't wait to get cutting .Closer pic of bottom edge. Had to cut along the line of shinny and textured plastic.
