Anyone used Fogstar Batteries ? They look pretty good.
Hi @Huba - I think I have a failing AGM LB which is indicated by issues with my fridge.Just as an update to this, my ctek 250se is now behaving the same as Dellmassive described in his testing, letting the battery drop to 13.3v before then returning it to a higher state of charge, this equates to the battery dropping to about 70%. I've ask Fogstar if there's anything I can change in the BMS settings but suspect i needed a new DC charger.
@Dellmassive Are the renology the current go to on DC-DC I would go for the 30 I think and limit the charging to 20 so wiring was kept the same, I have 200W of solar.
I ordered mid January and it came start of May. The battery has worked as expected. The Bluetooth monitoring works well, so am happy. I think it said it was going to arrive end of March when I ordered so it was late. I think they ask for a 10% deposit now rather than full payment I madeHi @Huba - I think I have a failing AGM LB which is indicated by issues with my fridge.
Very interested in going lithium and have found the Fogstar 100A. I see they’re preorder - if I can ask how long did you have to wait for yours? And are you happy?
It looks like a good option and info above is useful. My fear in the short term is whether a) I’d get it in time for a trip in July and b) whether I’d need to upgrade my charging hardware. I currently have a Sterling B2B and a portable Halfords smart charger that I can see has a lithium profile but not sure if it’s suitable.
Are you happy with it? My AGM has finally let me down, so the Fogstar 105 is my front runner at the moment. I have Renogy DCC50SFor info : as at today Fogstar 105A lithiums are currently in stock (even though website suggests still on preorder). Bought today. Being delivered tomorrow. Looking forward to the upgrade.
So far for me - absolutely spot on. Very little charge fall off (appreciate my previous AGM must have been shot) but for the price and that I’ll get twice the usable Ah out of it - can fault it for the price so far. About to go on a trip, so will get its first real world test. Not much of a premium over the AGM I was going to get - and 10yr warranty. Next day delivery. Seems like a no brainer.Are you happy with it? My AGM has finally let me down, so the Fogstar 105 is my front runner at the moment. I have Renogy DCC50S
I've not had any issues like you describe and run a fridge while away. I have a tracker and battery monitor which draws a little current, not sure if that makes any differenceWe just had our first week away with the new 105Ah fogstar. It's been fine except for one night it seems to have switched itself off for half an hour. At the time there was very little constant current drawn, and the fridge was on, which means drawing about 3 to 4 amps while the compressor runs for 5 mins, then no draw for 10 minutes or so.
No harm done this time, but I'd like to fix this issue. Before I raise a ticket with fogstar, has anyone any suggestions?
The issue is resolved now by a replacement battery.We just had our first week away with the new 105Ah fogstar. It's been fine except for one night it seems to have switched itself off for half an hour. At the time there was very little constant current drawn, and the fridge was on, which means drawing about 3 to 4 amps while the compressor runs for 5 mins, then no draw for 10 minutes or so.
Nice,The issue is resolved now by a replacement battery.
The old one would regularly, maybe once a day/night, turn its' output off, even though the load was present (compressor fridge), after about 10 minutes it would come back on. In the fault history the discharge overtemperature event was counting up. My victron BMV702 was recording the 'shutdowns' in the history.
My van wiring has been perfect for 3 years with the previous AGM, so pretty sure that the fault was with the battery itself.
Anyway, after a few attempts, with the assistance of fogstar, to alter settings, a replacement battery was agreed. Fogstar support were pretty good, aside from a couple of times when they asked the same questions I'd already answered. I would advise anyone going through this process to do it by email.
The replacement battery has been in a week or so now, with no shutdowns and no reported errors.
