Yep, it's actually pretty straightforward, took about 20 mins;
- Using a trim tool you need to carefully remove the facia that surrounds the head unit and has the middle vents incorporated into it - the head unit stays in place
- There is a small nut that holds that unit the RAC black unit in place (don't worry about those two little screws on the front, they don't actually do anything!). The nut is at the back an can be accessed now you have freed up the vent space - it will all become clear once the facia is off!
- If you undo the nut you should be able to carefully push/pull that black box out - be careful as you only want to slide it out enough to get access to the back of the buttons to disconnect the wires (which just have a clip you need to push in) - blue connector for the start stop and white for the hazards
- The front of the buttons will just pop off with a trim tool and you can slide the whole black unit out and you have your mini shelf back!
- Relocate the cables to their original positions above and then connect them to the backs of the buttons in the original factory position
