I had a re-read of the Eton threads recently and didn’t see anyone had installed an amp.
Regarding a sub, I’m in the same boat with space - I did ponder as to whether a sub would fit in that dash speaker cover that Van-X are now selling... not sure how that would cope with rattles, mind.
I fitted a VIBE micro amp with the Blamo`s . . . . . Audio Upgrade Stage-1 . . . . Blam Relax 200rs Speakers From Skipton.
as a temp measure until i get the full amps/sub setup.
Plug N Play . . . . sort of. (needed to chop out some of the rear plastic cage to make room for the new loom)
i just squeezed it up above the glovebox/cubby hole for now
VW T6 Vibe Micro Amplifier Plug & Play
thanks I’ll check it out.
I have recently installed Eton speakers without an amp (with the factory head unit) and I am very impressed with them. I personally don't feel they need an amp - probably worth trying them without and then deciding!
We have done a few with a small Kenwood amp and it really brings them alive
Where do you mount it normally? Can you supply?
The misses has just got an A3 with a Bang and Olufsen system and it’s just made me realise how rubbish the T6 system is.
It can mount behind the top pocket ( top glove box if you have comfort dash) or under seat
We can supply this along with the Etons
If you want to go one better that the A3 B&O system then out Signature audio setups will blow it away
I suggest amping them you probably will find you will not want a sub.
Also a compromise on a sub can result in poor performance
I can supply the small Kenwood (adjustable gains and crossovers ) amp as a plug and play set up for £150.00
This is a four channel so can run rear speakers, or if you want you could run the door and tweeters separately but would require more wiring/Labour
Started the install today.. Rain has really been causing me some troubles trying to get started.
Got the door speakers in.. Tweeters to go tomorrow.
So amp behind the dash.. Anyone got any pics of where and how?
Cant help with position or amp install, but I would be really interested in if you ran the speakers for a week or so before the amp and then review![]()
Pm has been sentHi I have a set of the Etons. I’m interested in the Kenwood. Can you pm me some more details please inc a phone number. I would like to phone and sort things tomorrow (Friday) pm. Thanks.
