No it’s not I’m afraid but I have other software that can do it
Come on @Pauly spill the beans, what software are you using, hehe.
YesDoes anyone know if Carista alters the 'bits' when selecting options as in it could undo some alterations done with VCDS?
I await any more info you have Tony, thanks. Also if you find a way of stopping the re-gen charging. I don't like hearing the AC fan speed going up every time you lift off the accelerator and back down when you press the accelerator again. The voltage goes from 12v to 15v.
However I was so fed up with it I fitted a nice little memory device bought on eBay for £28.99. See item 322352078637 by seller idegencris.
You connect it to the back of the switch. It is only three wires and he even confirmed the method for removal of the switch and the wiring. Which ever position you decide to leave it in, it will remember that for the next start so you can have it as normal stop/starting or if you turn it off it will do that 4 seconds after the next time you turn the ignition on.
The radio trim needs to be removed in order to push stop/start switch out. The switch comes out easily but the radio trim was tight but I can advise where the catches/lugs are so you know where to pull it. I then pulled to harness out through the opening left at the side of the radio to work on it. I backed the three wires out of the plug as that way I could finish it off with heat shrink and then push the pins back in. I do tried to add a picture of it and the picture the seller gave me explaining the switch removal. He also told me the wires are connected as such (I did confirm and luckily they are all on one side of the connector).
(Module -- Car)
BLUE -- Brown/Black (signal)
RED -- Black (acc/ignition)
BROWN -- Brown (Gnd)
The finish off this little device is absolutely brilliant.
View attachment 14279 View attachment 14280
The eBay listing says:-In not 100% sure what you mean but the dash switch is a momentary switch returning a negative signal to the BCM
As a general rule of thumb Any cable that is Brown is a perm negative and anything that is brown with a coloured stripe is some form of switched negative
To be fair, all bcu switching is negative but this feeds the engine ecu directly so the odd man out.Now don’t i look stupid
Why not just share it with us. That's what the forum is all about.I have the answer to the stop start problem if any one is interested
I know they make life easy but I hate them as it is really easy to damage the main conductor.If anyone is thinking of using the little 'dongle' thing mentioned earlier in this thread then I 100% suggest using something like these for the connections:- Wire Connectors
(Will make your life a million times easier on this job!)
