Yes the Ring will work, it can cope with a solar input of 50volts. The only problem is it's mahoosive and I don't think I have space for it under the seat.
Went to visit Colin at @VWVC yesterday to have my Caravelle floor and seats fitted. I'm over the moon with Colin's work. All done in a day. If you want OEM rails or seats fitted then this is the guy to see.
I saw that you lined the cab floor with Silent Coat.
Was that just 2mm ? Are you going to add a sound barrier in the front that will raise the cab floor.
Did you do the back with Silent Coat before the Velle floor went in?
Looks great! Having slept in my Kombi before a recent Gravel race event, I’ve decided I need more comfort before a long day in the saddle - I think it’s called getting old.
I used 2mm silent coat on the cab floor. I'm not adding anymore thickness to it. The cab carpet is thick enough IMO and it will cause problems with the seat bases, side steps and b pillars if I raise it up. I will however raise the back edge by about 8mm so that the carpet is the same height as the 'velle floor where the 'velle trim strip between the cab and the back fits.
I didn't put anything on the flooring in the back as it would affect the height of the floor in relation to the rails. The thickness of the floor plus carpet on top is a good enough sound barrier. If not, I'll just turn the stereo up![]()
Where have you got your hidden fixings from? Those panels look nice, but thicker than original so how have you got the fixings to pass through?Starting to make a bit of progress tonight now the light nights are here. I’ve removed the C pillar covers that Van Doc had cut the carpet and screwed to the van. Recut the panels, added hidden fixings and a bit of shape detail and a USB and 12v point.
Bosh! SimplesNah, they’re made from the old roof lining. 4mm thick so the hidden fixings fit fine. I cut the shape out of the middle and stuck another piece over the hole on the back![]()
Blinking clever this.Before the roof was done I started phase 2 of my audio install. The signal processor has a double rotary knob. The rear controls the rear speakers and the front controls the sub. You can click the front button so scroll through 10 pre-set programs. There's an led that changes colour to indicate which program you're on. Its massive and it's bright.
I didn't want to give over a full switch blank to this led so I decided to fibre optic it to the switch. I found an old audio fibre optic lead to sacrifice and fitted it to the switch blank with the control knob on.
I butchered up on of the plugs to push the led into on the other end and cut the end off with a sharp knife. The result looks great.
