Markab04
I put my 2017 t6 in garage for cam cover gasket and injector oil seals they said 3 hour job, I phoned them after it had been in all day they said its running rough when put back together and showing cam sensor on tester, so they changed that , then phoned and said still running rough 2 injectors showing in the red on there tester, and said injectors are going to be expensive, it was running fine before it went in for the oil Leak and looks like theyve, caused these problems when taking injectors out, is it down to the garage to foot the bill for the injectors as anyone else had this problem tia
