cam belt
  1. T6ChrisO
    Timing Belt - Safe or risking it?
    Not had chance to do the belt change on the Crafter yet. Its due on 133k and it currently sits on 132,100 miles. I might possibly need to do a 500 mile round trip tomorrow. Should I be nervous or do VW err on the side of caution with 133k? Thanks all
  2. T6 Pilot
    Timing belt 2019 CXHA interval
    Guys just a quick one 2019 T6 2.0 CXHA engine. What’s the timing belt internal it currently has 90K Km on it.
  3. H
    Cambelt Change DIY CXHA?
    Hello, Long story short planning on doing my own cambelt change on my 2017 T6 CXHA. I’ve studied Vag tech video and read manufacturer instructions but have couple questions. 1) Is it essential to loosen both Camshaft pulley and also high pressure fuel pump one? 2) I have noticed in videos...
  4. S
    Engine replacement cost?
    Hi everyone. I have a 2017 caravelle executive that has broken down. Did any of you ever had to get his Caravelle (or t6) engine replaced and how much did you have to pay for? Mine had internal damage due to camber belt parts broken and damaging the engine and I have been quoted two very...
  5. L
    Broken pulley - repair with warranty question
    I’ve written previously about a VW T5 Campervan that I put a deposit on then was told that it broke down between the garage and dealership after having the cam belt replaced. I was told by the salesman that the cambelt pulley had failed and advice from this forum was that this could have caused...
  6. Jonesy123
    CAMBELT REPLACED and now having issues
    I'll keep it short. VwT6 - 2016 108,000 CAAB engine. Cambelt and waterpump done this week. Zero faults or issues on vcds or otherwise until today in the entire time I've had the van. Passed every MOT its had. Great van. Daily driver. Errors taken from calista OB2 (note...same on VCDS also...
  7. AdamT
    Toothed Belt change
    Can anyone who’s had their van a while and had it serviced by VW tell me if this relates to cam belt change ? And if so would VW do the water pump at the same time as a matter of course? It’s part of the history print out that I was given by independent dealer upon purchase of my van but not...
  8. Hamster67
    Timing off after only 10k
    Hi folks I had my timing belt done at 69k only 14 months ago, recently I have had issues with faulty gauges and lumpy starts. The censors that were faulty have been replaced but the diagnostic report said the timing was off by 0.1 of a second. They said this is normal as the belt can stretch...
  9. n10n
    Show us your used parts!
    Had timing belt, water pump, aux belt and related rollers changed at 90000km / 6 years. Here’s some photos of the removed parts. 1. The changed lot, apart from the belts 2. Aux belt looks pretty much impeccable 3. Timing belt looks little bit worn but not bad. Didn't find any damages...
  10. osman
    Cam belt and pump replacement yet again !
    So I’ve just had my van in after breaking down due to a problem with the clutch diagnosed by The AA as a leaking pump / fluid situation and it’s been diagnosed by the garage …….no problem with clutch it’s a rattling fly wheel causing it to over heat ! And whilst they were diagnosing this little...
  11. graffo
    Cambelt change
    Hi Save me trawling though 100s of threads. Just booked my T6 2018 T30 150 TDI Highline in for a major service and MOT. They asked if I wanted a cambelt change as its 4 years (as recommended by VW) but also asked if it was high mileage or not and therefore my choice. I've declined at present as...
  12. C
    Timing belt failure. is my mechanic at fault? (with Pics)
    So last week I had the timing belt and water pump done at the local garage. 52k miles 2018 150hp It had been squeaking and I was planning on taking it back to see what was going on but then the squeak went away so there was nothing to show him. This was Friday. Tonight, I packed my caravan and...
  13. O
    Timing belt change
    we have a 2019 150bhp T6 and I believe it’s due a timing belt change every 120000 miles or 4 years. We’ve only got 37000 on the clock but I presume we should still make sure they change the belt yes? Thanks.
  14. T
    Renewal of Auxiliary Drive Belt - When ?
    Evening All. Advice needed please. At what interval / mileage should this be changed ? Further.....should the tensioner be renewed as a matter of course ? I suppose the cost will be eye-watering......My van is 5 years old and has covered 37,000 miles. Wolfe.
  15. Norberto Trevino
    LUK brand timing belt and accesories
    Hi, Does anyone here has had any experience (good/bad) using the LUK brand for the timing belt kit that also includes the water pump? The typical brand I used to find was the INA, but currently is unavailable, except for a mixture of INA pump plus DAYCO the rest of the parts of the kit. Your...
  16. Adever121
    Glow plug light on off no limp mode
    New to the forum so hi to all and I understand this a t6 forum but just looking for some resolution as can't find anything online and it's left me scratching my head. I have 2013 t5.1 102 caab I've recently noticed a strange fault with the van, the van drives fine but when the engines pushed...
  17. S
    Power steering pump - replacement cost.
    Hi all. Has anyone had any experience with replacing power steering pumps? My dealer has informed me that’s it’s weeping oil and recommends it to be replaced. The van is due a cam belt and water pump which they have quoted £890 to conduct the work, PLUS a further £968 to replace the power...
  18. VesselPal
    Non-switchable or switchable water pump
    I'm looking for a water pump & timing belt kit. I've been looking at Gates, HEPU, INA but am having trouble figuring out wether I need a switchable or non-switchable pump. All websites point to both options so my only option is to call the VW dealer and beg them for a part number. Besides...
  19. R
    Cam Belt Changed - Now multiple errors including Stop Start
    Recently had my Cam belt changed and when I picked up the van it failed to start first time. Put it down to a low battery after being in the garage all day. For the following week the van refused to start first time often taking several goes at cranking over before it starts (2 - 3 minutes)...
  20. N
    Cambelt/water pump and DSG oil change - 5 year change?!
    Hi Guys just booked my 2018 T6 150 DSG in for service and Mot as it's 4 years old in January I was expecting to replace cambelt / water pump and DSG gear box oil... VM service informed me that according to the chassis number my engine and DSG box are on 5 year schedule!
