Airbag light on - code 01321 [Resolved]
Montego
Hi guys my 2017 t6 highline is showing fault 01321 no comunication with air bag module, and won't clear with my delphi diagnostics any ideas where the unit is please ? and any help to diagnose or check wiring or fuses related cheers Jon
On the floor under the fuse box that’s under the gear lever
Thanks Loz- Update i found it and it was rusty inside reckon someone had valeted cab out with pressure washer, dropped lucky and got a T6 ecu for £35 off Ebay , same part number , plugged in light went out , no fault codes in the ecu, and was plug and play, so people saying they need coding to vehicle, I cannot comment if there right or wrong or i was just lucky, other than to say not in my case , cheers Jon .
