Navigation fault or wrong coding?
tomek12
Hi I've done scan and delate error but this error come up again.
Everything works as should but fault come back. Should I change coding or do any adaptation?
Last scan and gateway list:
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 2K0 035 279 B HW: 2K0 035 279 B
Component: RNS315-EU H85 0501
Serial number: VWZAZ2R0824208
Coding: 000002110200140000039002
Shop #: WSC 02754 790 50316
ASAM Dataset: EV_RNS315EUV2UDS 001705
ROD: EV_RNS315EUV2UDS.rod
VCID: 2952554848F923099E-807C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V12 0078
2 Faults Found:
1048652 - Telephone Microphone
B1048 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 32484 km
Date: 2018.10.17
Time: 11:52:01
1048641 - Control Module Incorrectly Coded
U1014 00 [009] - -
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 93
Mileage: 32484 km
Date: 2018.10.17
Time: 11:52:01
Correction for sound system: OK
Traffic sign display: OK
CD changer: OK
Status of antenna 2 for radio: OK
Digital radio (DAB): OK
Antenna diagnostic: OK
Telephone baseplate diagnostic: OK
Speaker status: OK
Rearview camera: OK
Telephone Transceiver: ERROR
Any advice what to do I will be apreciated.
Code:
Chassis Type: 7H (6N0)
Scan: 01 03 04 08 09 10 15 17 19 25 37 56 69 77 0B
VIN: WV1ZZZ7HZFH136596 Mileage: 112190km-69711miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
69-Trailer -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels: 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GH HW: 03L 907 309 M
   Component: R4 2,0L EDC H45 6303
   Revision: 26H45--- Serial number: 00000000000000
   Coding: 01194012232400080000
   Shop #: WSC 02757 790 50316
   ASAM Dataset: EV_ECM20TDI01103L906019GH 003004
   ROD: EV_ECM20TDI01103L906019FM_003.rod
   VCID: 77F64330CECD45F9D8-8022
2 Faults Found:
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
          Intermittent - Not Confirmed - Tested Since Memory Clear
4481 - Cruise Control Switch (E45)
          P0568 00 [032] - Implausible Signal
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (-----) Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L HW: 7E0 907 379 L
   Component: ESP MK25A XT H50 0113
   Revision: 00H50001
   Coding: 108724AD09A7089B24A7907ABA6412
   Shop #: WSC 02757 790 49152
   VCID: 3B7E9F00BA65A199FC-806E
No fault code found.
Address 04: Steering Angle (G085) Labels: 6R0-959-654.clb
   Part No SW: 6R0 959 654 HW: 6R0 959 654
   Component: LENKW.SENSOR H07 0070
   Serial number: 25021504651881
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EF85614E1F774B19B-802A
Address 08: Auto HVAC (J301) Labels: 7E5-907-047.clb
   Part No SW: 7E5 907 047 BM HW: 7E5 907 047 BM
   Component: Climatic-T5 H20 0506
   Revision: 00001012
   Coding: 0000000002
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaticT5.rod
   VCID: 7BFE5F00F2E56199BC-802E
Address 09: Cent. Elect. (J519) Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 P HW: 7H0 937 087
   Component: BCM T5GP H+4 H34 0424
   Revision: BO034001 Serial number: 0673 069151527
   Coding: A0B4793A0AE13411922848106C2B8CDC0080632F60840000320000000800
   Shop #: WSC 02739 790 12345
   VCID: 4182EDE8D889CB49A6-8014
   Subsystem 1 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT 003 8653
   Serial number: KU0KU004031550635773
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT 003 8653
   Serial number: KU0KU005031550643777
   Coding: 0000A0
   Subsystem 3 - Part No: 7E1 951 172
   Component: DWA-Sensor 00 001 0104
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO H05 1501
   Coding: 000000
   Subsystem 5 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 6 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6 H07 0023
   Serial number: 70000000000000876347
   Coding: E20000
3 Faults Found:
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 15
                    Reset counter: 56
                    Time Indication: 0
03302 - Response Closing Status of Passenger's Door
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 174
                    Reset counter: 30
                    Mileage: 92362 km
                    Time Indication: 0
                    Date: 2016.08.10
                    Time: 11:57:32
03303 - Response Closing Status of Rear Left Door
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 30
                    Mileage: 92362 km
                    Time Indication: 0
                    Date: 2016.08.10
                    Time: 11:57:32
Address 10: Park/Steer Assist (J446) Labels: 7E0-919-475.clb
   Part No SW: 7E0 919 475 K HW: 1Q0 919 475
   Component: PARKHILFE 4K H03 0106
   Revision: -------- Serial number: 32991506103982
   Coding: 118001
   Shop #: WSC 12345 123 12345
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K.rod
   VCID: 3A709A04BD5F9891E7-806E
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
   Part No SW: 7E0 959 655 B HW: 7E0 959 655 B
   Component: VW10Airbag009 H07 0013
   Revision: -------- Serial number: 003HL00W4V9V
   Coding: 000000000000000000000000000000003039
   ASAM Dataset: EV_AirbaVW10BPAVN750 A01026
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 356A8938944177E90A-8060
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
   Part No SW: 7E0 920 970 N HW: 7E0 920 970 N
   Component: KOMBI H04 0805
   Coding: 760A01
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04727
   ROD: EV_Kombi_UDS_VDD_RM09_VN35.rod
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901 HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 042300
   VCID: 70E4782CA3A312C119-8024
1 Fault Found:
00470 - Company Comfort Databus in Single Wire
            011 - Open Circuit - Intermittent
             Freeze Frame:
                    Fault Status: 00101011
                    Fault Priority: 2
                    Fault Frequency: 51
                    Reset counter: 67
                    Mileage: 106222 km
                    Time Indication: 0
                    Date: 2017.08.14
                    Time: 12:04:43
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234 HW: 5K0 953 234
   Component: IMMO H04 0805
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6AD06A448D7FE81157-803E
   Data medium:
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 32484 km
                    Date: 2018.10.17
                    Time: 11:52:01
          U1014 00 [009] - -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 93
                    Mileage: 32484 km
                    Date: 2018.10.17
                    Time: 11:52:01
                    CD changer: OK
                    Speaker status: OK
                    Rearview camera: OK
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
   Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
   Component: Anhaenger H12 0100
   Revision: 3A001001 Serial number: 00000381522758
   Coding: 0100000100000000
   VCID: 3064B82C632352C159-8064
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
   Part No SW: 7P6 035 730 M HW: 7P6 035 730 M
   Component: TELEFON H16 4217
   Revision: 1B001001 Serial number: 00007670255987
   Coding: 0A01010000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C7C9C1CB76BA6A1F5-8068
Any idea why "56-Radio" is present at the beginning of the AUTOSCAN
and then the details for
"Address 56: Radio (J0506)"
are actually missing?
Yeah you right address 56 missing.
I double check tomarrow.
I do another scan
56 doesnt belong in a T6 or am i missing something ?
is this a retrofit job or factory, a bit more background may be helpful
has it ever worked ?
can you make calls over bluetooth ?
Well I have T5.1 (15 reg.) and bluetooth works ok. (Looks like is factory no retrofit)
I got this van about 4 weeks.
I checked (another scan) and looks like the same no Address 56 .
I think found problem.
Address 37 navigation
Byt 3
Bit 5 was not ticked
After change coding done test no fault so looks like is coding .
Today drive to work use BT everything works ok.
Done scan after work again no fault.
So problem solved.
Happy day
Any way thank you "dzięki" for help
