Hi all, I’m hoping for a bit of advice regarding some issues I’m having with my van.
My battery light is on, my battery isn’t charging, and I’m struggling to figure out if it’s an alternator, battery control module or wiring issue.
I’ve scanned the van and I’m getting a 02252 code, although I will admit I’ve been seen this code intermittently in the past but It’s never seemed to cause an issue and certainly hasn’t caused the battery light to come on or to have low voltage.
I’ve checked the yellow and green linbus wire that runs from the battery control module to the alternator, and it doesn’t seem to have continuity. Having seen a few threads here with similar issues, the advice is to bridge the alternator directly to the BCM - but when I do this it doesn’t make a difference, the voltage across the battery stays at around 11.5v.
Not sure what the next steps are, so any advice would be gladly appreciated. I’m wondering if it’s possible that the continuity/linbus issue is and old one, and that the alternator has now broken meaning I’ve actually got two problems to fix? Does the alternator kick in automatically at a certain voltage even if the BCM/limbus isn’t connected?
Cheers guys!
John
Cheers guys!
John
