Great info, but does the fact the tensioner fouls the idler pulley indicate there is a problem?
Yes, it means the belt is seriously wornGreat info, but does the fact the tensioner fouls the idler pulley indicate there is a problem?
Oh it’s changed. What I’m trying to say is, I wouldn’t have thought that by design a worn belt would allow the tensioner to touch the idler. Surly the tensioners travel should stop before that happens?Yes, it means the belt is seriously worn
Change it ASAP
The belt should not get that worn that the tensioner does make contact. If the tensioner travel was restricted, you'd probably have the belt shedding, possibly with further damage.Oh it’s changed. What I’m trying to say is, I wouldn’t have thought that by design a worn belt would allow the tensioner to touch the idler. Surly the tensioners travel should stop before that happens?
I agree, it shouldn’t be left that long.The belt should not get that worn that the tensioner does make contact. If the tensioner travel was restricted, you'd probably have the belt shedding, possibly with further damage.
One is closely followed by the other, you’re correct in highlighting it, just another easily avoidable design flaw, no surprise.I agree, it shouldn’t be left that long.
I think the belt shedding would probably be better than catastrophic failure when they touch.
My reason for asking the question really was to check there wasn’t something else causing the pulleys to touch other than a stretched belt, ie idler pulley faulty. I was checking it wasn’t specific to my van because of another issue. No one’s really said they have had the same issue yet, just that my belt was overly worn.One is closely followed by the other, you’re correct in highlighting it, just another easily avoidable design flaw, no surprise.
Design engineers are often ‘too intelligent’ for their own good, there is a train of thought that following service intervals and procedures eliminates all failures.
It shows there a serious problem with servicing and inspection. The belt should never be allowed to wear anywhere near this much, so it's irrelevant whether the tensioner has a stop or not.Great info, but does the fact the tensioner fouls the idler pulley indicate there is a problem?
So is the tensioner supposed to stop before fouling or not?It shows there a serious problem with servicing and inspection. The belt should never be allowed to wear anywhere near this much, so it's irrelevant whether the tensioner has a stop or not.
Yes, @oldiebut goodie that is well established by now, thank you, but, does the tensioner pulley travel so far as to foul the idler pulley ordinarily I wander?The point isn't relevant - with correct servicing it will not normally reach such a position.
