Recently had my Cam belt changed and when I picked up the van it failed to start first time. Put it down to a low battery after being in the garage all day.
For the following week the van refused to start first time often taking several goes at cranking over before it starts (2 - 3 minutes). Stop Start Error is also displayed on the dashboard. Thought it was just a low battery so connected the charger for a day and driven about 500 miles.
The van now starts most times but still getting the Stop Start error. If I forget to turn off the Stop Start and it kicks in the van always fails to start. Have to turn off the ignition and try and start up manually.
So I've taken it back to the garage that swapped the Cam belt and pump and they have confirmed the following errors:
P034100 Camshaft position sensor
P20EE00 SCR Nox
P06EF00 Engine Restart
P012100 Throttle pedal position
03442 Return message closing status of rear lid
U140000 Adaptive Cruise Control Function Restriction.
From reading another thread with similar issues after a Cam belt change it could all be caused by them incorrectly fitting the Cam belt.
My initial thoughts were a damaged / failed battery.
P20EE00 SCR Nox
