Both same clocks I adjusted mileages and immo to match the oringal cluster ( which was old style t5 cluster z( not not needing rear brake lights I meant what powers the cluster lights up behind the dails and needlesthe lights wire back to the J519 BCM module,
under the dash clock , above the peddles.
its shown on the schematic above.
post a few pics of the van and rear lights.
is it a T5.1?
you have two different clocks shown there, one with 89k on it, and one with 100k and one shows imob issues as no key.
so what are you trying to do?
example T5.1 HL clocks
Thankyou no wonder they won’t work as I’ve audi engine set up I had to use audi canbus , , I’ll have to think of another way to sort them buggersAmbient light circuit.
Led. Pwm driver from the BCM with dash dimmer control.
Is there a higher res version of these diagrams? I can't make out the details. (Trying to figure out an issue with my RH rear turn signal) These diagrams might help with my fault finding. Thanks.Not sure why but in my wiring diagrams the chapter for 5.1 tail lights say drop side ??
Anyway i imagine the wiring is the same, just check the wire colours match
Left
1 - black/red - brake
2 - green/black - reverse
3 - brown - negative
4 - black/white - indicator
5 - grey white - foglight
6 - grey/black - tail light
Right
4 - black/green - indicator (black/yellow with factory fitted towbar)
5 - grey/white - foglight
6 - grey/red - tail light
They are all in the download sectionIs there a higher res version of these diagrams? I can't make out the details. (Trying to figure out an issue with my RH rear turn signal) These diagrams might help with my fault finding. Thanks.
Thanks (I have looked, several times) but cannot find them. What am I doing wrong. Many of the links say "VIP Membership is required" - I upgraded yesterday. Still confused.They are all in the download section
Hi PaulyThe diagrams posted above are relevant to this thread, all the T6 stuff is posted in the downloads section
What is it exactly you are looking for ?
Thanks. I'll report back if I have any successThe rear right indicator wiring goes to pin 15 in the 17 pin plug called T17f that is located under front seat
From there it goes to the BCM in dash to plug T73b pin 15
Morning Paul,The diagrams posted above are relevant to this thread, all the T6 stuff is posted in the downloads section
