My van has a waeco crx0500 12v fridge fitted. It used to run both when on hook up or off the leisure battery when off grid, now however it only works when on mains and when not connected to mains shows a fault of “excessive fan current” which is explained in the manual as the fan load on the electronics unit is more than 1 amp.
I thought it might be the battery but I’ve tried another new one and that hasn’t cured it.
I've tried to get an engineer from the local dometic (waeco) agent to look at it but they seem to be too busy to return calls.
Can anyone suggest a likely cause and or recommend an engineer who will look at it in the Bedfordshire area
thanks
thanks
