Hi all - the RV branded (Dometix CRX50 copy) has possibly packed up on me. Getting 3 flashes error code so someting to do with a stuck rotor or too high pressure difference. I've removed it, unhooked it from power, left it overnight, reconnected and still the same. It had been working fine.
Powered from the CBE fuse box in the back of the van. I have read about voltage drop causing issues, but my leisure battery is in good condition and the fact its been working fine makes me think its something more than that.
Not too sure what to do as have no warranty, it was in the van when I got it.
Thinking about replacing it it completely and was looking at the Dometic NRX50 which I understand is the newer version of the CRX50.
I was also looking at the wiring loom sold by Magnum Motorhomes that has 6mm wire - https://magnummotorhomes.co.uk/.../12v-supply-cable-for.../
I don't know that much abouty the electrics so have a coupe of simple noob questions.
Does anyone have experience of the new NRX50?
To install a new fridge with the wiring loom shown, would you try to feed a new wire (I want to upgrade to 6mm to avoid any potewntional problems) from the CBE fuse box or just connect it straight to the leisurte battery as that loom does have an inline fuse?
The leisure battery is under the front drivers seat so literally right next to the fridge. What do I need to know and what is the process of attaching the new fridge wiring loom dirdct to the battery...is there an order of doing things like when you jump start a car i.e. take off the negative terminal first etc etc?
Apologies for the cluelessness of this post
