VCDS cable vendors
JamesWebb
VCDS User
Hi there,
Can you suggest where I might buy the correct VCDS interface cable for a 2021 T6.1?
Many thanks,
JW
Another vote for Gendan. You want the Hex V2 or Hex-net.
Ok here we go!
I am now a proud owner of a Hex-V2 (only 3 VIN - as I don't want to be responsible for destroying lots of other folks VAG wagons!)
. . . and so the questions start . . .
Is there an idiots guide to the software? - as I'm getting 'Status: Malfunction 0010' on every module!
Thank you - in advance.
JW
Reactions: mmi
Ignition needs to be ON.
Thanks for the rapid response mmi - but it was!
I'm wondering that as I removed the instrument cluster (and later replaced it) and the gateway module (and then replaced it) - do I need to do a 'reset' of any kind?
Hmm... interesting. Could you please post an Auto-Scan - just use default options (Auto-detect etc.) and Start.
I've done that a few times - and would happily post here but the forum says I've gone over the 50,000 characters:
I'll split it in two . . .
  • Wow
Reactions: mmi
Code:
Saturday,19,November,2022,19:44:07:38189
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(Parallels)
VCDS Version 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
VIN: WV1ZZZ7HZMH054892   License Plate:
Mileage: 7544km-4687mi   Repair Order:
Chassis Type: 7H-VN46 (3Q0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F 75
VIN: WV1ZZZ7HZMH054892   Mileage: 7544km-4687miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
75-Telematics -- Status: Malfunction 0010
Address 01: Engine (J623-CXHC)       Labels:. 04L-907-309-V2.clb
   Part No SW: 04L 906 056 SC    HW: 04L 907 445 M
   Component: R4 2.0l TDI   H01 9970
   Revision: 23301001
   Coding: 001140144344050900000000000000000000000000000000
   Shop #: WSC 00012 790 00065
   ASAM Dataset: EV_ECM20TDI03004L906056SC 005007
   ROD: EV_ECM20TDI03004L906056LE_005.rod
   VCID: 00598D9C0A8A51DBEB2-8055
   VINID: 9E606AAAA1D8A9D60014420908F4904341
2 Faults Found:
25810 - No Communication with Instrument Cluster
          U0155 00 [032] - -
          [Lost Communication WithInstrument Panel Cluster (IPC) Control Module]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 2
                    Mileage: 7517 km
                    Date: 2063.15.31
                    Time: 16:00:00
                    Engine RPM: 0.00 /min
                    Normed load value: 0.0 %
                    Vehicle speed: 0 km/h
                    Coolant temperature: 10 °C
                    Intake air temperature: 4 °C
                    Ambient air pressure: 980 mbar
                    Voltage terminal 30: 10.812 V
                    Unlearning counter according OBD: 40
                    Accelerator pedal travel: raw value: 0.00 %
                    CAN status - engine control module: 0
                    Cruise Control System (CCS): status: Initialization
                    selected gear: Shifting process active
25126 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Mileage: 7517 km
                    Date: 2063.15.31
                    Time: 16:00:00
                    Coolant temperature: 9 °C
                    Intake air temperature: 0 °C
                    Ambient air pressure: 1000 mbar
                    Voltage terminal 30: 11.859 V
                    Acceleration: 0.000 m/s²
                    Average vehicle speed: 0.00 km/h
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake function status-ABS intervention: No
                    Drivetrain coordinator: brake function status-ESP intervention: No
                    Drivetrain coordinator: brake function status-EDL intervention: No
                    Drivetrain coordinator: brake function status-ASR intervention: No
                    Drivetrain coordinator: brake function status-MSR intervention: No
                    Drivetrain coordinator: brake function status-Driver braking: No
                    Drivetrain coordinator: brake function status-HDC active: No
                    Drivetrain coordinator: brake function status-ESP invokes TSK braking: No
                    Drivetrain coordinator: brake function status-EPB active: No
                    Drivetrain coordinator: brake function status-ASP intervention: No
                    Drivetrain coordinator: brake function status-ADS intervention: No
                    Drivetrain coordinator: brake function status-Stopping distance reduction2 warning jolt: No
                    Drivetrain coordinator: brake function status-ESP sampled passive (ESP off): No
                    Drivetrain coordinator: brake function status-ASR sampled passive (ASR off): No
                    Drivetrain coordinator: brake function status-ESP recognizes vehicle at rest: No
                    Drivetrain coordinator: brake function status-ACC stopping distance control active: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor not available: No
                    Drivetrain coordinator: brake fault status-Deceleration sensor malfunction: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
                    Drivetrain coordinator: brake fault status-ESP system malfunction due to inaccurate engine torque: No
                    Drivetrain coordinator: brake fault status-ESP indicates TSK message consistency error: No
                    Drivetrain coordinator: brake fault status-TSK/ESP handshake error: No
                    Drivetrain coordinator: brake fault status-ESP automatic engagement malfunction: No
                    Drivetrain coordinator: brake fault status-Brake light implausible: No
Readiness: N/A
Address 03: ABS Brakes (J104)       Labels: Redir Fail!
   Part No SW: 7LB 614 517 B    HW: 7LB 614 517
   Component: ESC_base      H01 0800
   Serial number: 08505890201207
   Coding: 30552452484CEE890C5C24AD12687726392324B8
   ASAM Dataset: EV_Brake1ESP90iBOSCHVN46X 003012
   ROD: EV_Brake1ESP90iBOSCHVN46X_003.rod
   VCID: 3FDB4E6037F4EE23D28-806B
No fault code found.
Address 08: Auto HVAC (J301)       Labels:* Redir Fail!
   Part No SW: 7LA 907 426 F    HW: 7LA 907 426 F
   Component: AC Manuell    H01 0602
   Coding: A03110000810030001000800504001050000000000000000800000000000
   ASAM Dataset: EV_AirCondiBHTCVN54XT6PA 001002
   ROD: EV_AirCondiBHTCVN54XT6PA.rod
   VCID: 46D55B84682EBFEB91E-8013
   Rear air conditioning block 1:
3 Faults Found:
459523 - Databus
          U1123 00 [008] - Received Error Message
          [Botschaft Dimmung_01 - empfangener Fehlerwert]
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Date: 2000.00.00
                    Time: 00:00:00
1048838 - Functional Limitation due to Energy Management
          B10CD 00 [009] - -
          [Funktionseinschränkung durch Energiemanagement Ruhestrom]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 126
                    Mileage: 6166 km
                    Date: 2022.08.21
                    Time: 19:33:20
                    Voltage terminal 30: 11.2 V
                    CAN input signal(s) status-Transport mode: On
                    CAN input signal(s) status-Static current measuring mode: OFF
                    CAN input signal(s) status-Windshield wiper: OFF
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Wipe wash: OFF
                    CAN input signal(s) status-Rear window heater actual value: OFF
                    CAN input signal(s) status-Back-up lamp: OFF
                    CAN input signal(s) status-Actual value of windshield heater: OFF
                    Blower reduction: No switch-off: no reduction
459011 - Databus
          U1121 00 [008] - Missing Message
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Date: 2000.00.00
                    Time: 00:00:00
Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Part No SW: 2Q0 937 090 C    HW: 2Q0 937 090 C
   Component: BCM A0 Std+   H11 0943
   Serial number: 00102032901570
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_BCMA0 206001
   ROD: EV_BCMA0_206_VN46.rod
   VCID: 323D1754F4A6334B2D6-8067
   Rain/Light Recognition Sensor:
   Subsystem 1 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  054 0206
   Serial number: S5Y20M11D12H00M03S46
   Coding: 0018EE
   Driver door control module:
   Subsystem 2 - Part No SW: 7L1 959 405 B    HW: 7L1 959 163 B
   Component: FHSG_DRV  001 0002
   Serial number: 00000000000045345199
   Coding: 1F000F
   Front passenger door control module:
   Subsystem 3 - Part No SW: 7L1 959 406 B    HW: 7L1 959 164 B
   Component: FHSG_PSG  001 0002
   Serial number: 00000000000044534061
   Coding: 050007
   Anti-theft alarm system sensor:
   Subsystem 4 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY202901VKQ
   Alarm horn:
   Subsystem 5 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0314
   Serial number: 00000000000048909261
6 Faults Found:
132619 - Voltage Supply; Terminal 30; Right
          B140E 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 7545 km
                    Date: 2022.11.09
                    Time: 14:50:17
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: OFF
                    Zusaetzliche Umgebungsdaten-Terminal 50 status: OFF
                    Zusaetzliche Umgebungsdaten-Low beam: Not operated
                    Zusaetzliche Umgebungsdaten-OFF: Not operated
                    Zusaetzliche Umgebungsdaten-Outside temperature: -50.0 °C
                    Zusaetzliche Umgebungsdaten-Automatic high beam assist: Not operated
                    Zusaetzliche Umgebungsdaten-Position lamps: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light left: Not operated
                    Zusaetzliche Umgebungsdaten-Parking light right: Not operated
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: On
                    Zusaetzliche Umgebungsdaten-last wakeup: keine Stoerschutzursache
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (CAN): OFF
                    Zusaetzliche Umgebungsdaten-Status Bremslichtschalter (HW): OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.7 V
134411 - Voltage Supply for Terminal 30 of Front Wipers
          B1899 13 [008] - Open Circuit
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 7545 km
                    Date: 2022.11.09
                    Time: 14:50:14
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.6 V
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          B131D F7 [008] - No Release by Immobilizer
          [Kommunikationsüberwachung Kombiinstrument zum BCM(Fehler DWA)]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Zusaetzliche Umgebungsdaten-Terminal 15 status: On
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.0 V
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [008] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 7545 km
                    Date: 2022.11.16
                    Time: 16:28:18
558869 - Databus
          [Kombi_01 Datenbus fehlende Botschaft]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Zusaetzliche Umgebungsdaten-voltage measurement: 10.8 V
919560 - Light Switch
          B126A 29 [008] - Signal Implausible
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Mileage: 7545 km
                    Date: 2022.11.09
                    Time: 13:55:15
                    Zusaetzliche Umgebungsdaten-CAN-Bus_aktiv: OFF
                    Zusaetzliche Umgebungsdaten-voltage measurement: 11.8 V
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-294.clb
   Part No SW: 5QA 919 294 J    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0073
   Serial number: 000150058320328
   Coding: 8451051801
   ASAM Dataset: EV_EPHVA18AU3700000 009053
   ROD: EV_EPHVA18AU3700000_AU27.rod
   VCID: 53F372D0AB7C1A43060-8007
6 Faults Found:
12670210 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Kombi_02 - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
13637408 - Databus
          [Bremsensteuergerät - ESP_02.ESP_Gierrate - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
13637419 - Databus
          [Bremsensteuergerät - ESP_02.ESP_Laengsbeschl - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
12670240 - Databus
          [Steuergerät für Schalttafeleinsatz-J285 - Gateway_72.WFS_01_alt - kein Signal/keine Kommunikation]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
13637426 - Databus
          [ESP - ESP_21.ESP_Systemstatus - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
13636864 - Databus
          [Dimmung - Dimmung_01.DI_KL_58xd - Fehlerspeicher auslesen]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
Address 13: Auto Dist. Reg (J428)       Labels:| 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 R    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H03 0372
   Coding: 2A00600201FF8748949C815560508700000000000000000004
   Shop #: WSC 00012 790 00017
   ASAM Dataset: EV_ACCMRRCONTIVW376 003016
   ROD: EV_ACCMRRCONTIVW376_003.rod
   VCID: 43D342905B1C8AC3B60-8017
10 Faults Found:
1080 - Databus
          [FAULT_TIMEOUT_KOMBI_01]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 15: 10.9 V
                    Control Module temperature: 11 °C
                    Vehicle speed: 0.00 m/s
                    Longitudinal acceleration: 0.47 m/s²
                    Adaptive distance regulation: status: ACC_Init
1227 - Databus
          [FAULT_TIMEOUT_KOMBI_03]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 15: 10.8 V
                    Control Module temperature: 12 °C
                    Longitudinal acceleration: 0.00 m/s²
                    Adaptive distance regulation: status: ACC_irreversible error
2101 - Databus
          [FAULT_ESP_STATUS_SYSTEM]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Adaptive distance regulation: status: ACC_StandBy
2068 - Databus
          [FAULT_TSK_IRREV_FAIL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Adaptive distance regulation: status: ACC_reversible_error
0822 - Databus
          [FAULT_EGO_FZG_GUETE_LAENGSBESCHLEUNIGUNG_SENSOR_DEFECT]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
0828 - Databus
          [FAULT_EGO_FZG_GUETE_GIERRATE_SENSOR_DEFECT]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
                    Voltage terminal 15: 10.7 V
0855 - Databus
          [FAULT_EGO_FZG_GIERRATE]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
0854 - Databus
          [FAULT_EGO_FZG_LAENGSBESCHLEUNIGUNG]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 166
                    Date: 2000.00.00
                    Time: 00:00:00
Wow... that's impressive list of faults. Certainly explains why every module is reported as malfunctioning. The van just got upset removal of components.
Under Auto-Scan please try "Clear all DTCs". Do another Auto-Scan to see if all modules were cleared (not necessarily on T6.1). Make a note modules still reporting faults.
Then from main screen > Select (control module) > Installed tab > Select a "faulty" module > Fault codes > Clear codes > Done etc.
Might also need to be driven a bit to clear some of the faults (to systems to recalibrate themselves, e.g. Help T6.1 start/stop and assist unavailable)
PS. By entering something unique each time into license plate you can put each scan into a separate log file.
Thanks for that mmi, I did dee the "Clear all DTCs" but didn't want to until I knew what I was doing - hence looking for the idiots guide! :rolleyes:
When anyone asked me about computer problems , I always suggested going into BRS mode. They said that sounded technical but I then replied that it stood for Big Red Switch - i.e. reboot the thing! It often sorted problems.
I'll try your suggestions and report back.
Thanks for your guidance - and time. :thumbsup: :)
JW
Reactions: mmi
Thanks for that link, mmi.
Here's the latest AutoScan - and as you suggested, clearing the DTCs removed most of the errors.
As it happens, I did connect the two camera wires to pins 7 and 17 of the Can gateway (soldered to the wires near the gateway plug) and tried to activate the HBA module through the software. I probably didn't do it correctly OR didn't wire it correctly, but whatever, it shows up un the latest AutoScan - here:
Code:
Saturday,19,November,2022,21:29:45:38189
www.Ross-Tech.com
VIN: WV1ZZZ7HZMH054892   License Plate: 21:29
Scan: 01 03 08 09 10 13 15 17 19 20 44 5F 75
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
20-High Beam Assist. -- Status: Cannot be reached 0100
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
   Revision: 23301001
Readiness: N/A
1 Fault Found:
          B10CD 00 [009] - -
          [Funktionseinschr‰nkung durch Energiemanagement Ruhestrom]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 7544 km
                    Date: 2022.11.18
                    Time: 05:09:16
                    Voltage terminal 30: 12.3 V
   Coding: 0018EE
   Coding: 1F000F
   Coding: 050007
   Alarm horn:
   Coding: 8451051801
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 2Q0 959 655 AD    HW: 2Q0 959 655 AD
   Component: VW22Airbag    016 0506
   Revision: --------
   Coding: 8800C00000000000400000CF008C40000065
   ASAM Dataset: EV_AirbaVW22BPAVW27X 001022
   ROD: EV_AirbaVW22BPAVW27X.rod
   VCID: 7F5B0E6077742E23928-802B
Address 17: Instruments (J285)       Labels:* Redir Fail!-SRI3
   Part No SW: 7LA 920 941 A    HW: 7LA 920 941 A
   Component: KOMBI         202 8400
   Coding: 27A40A002480260001882A010401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009071
   ROD: EV_DashBoardVDDMQBAB_VW27.rod
   VCID: 3E25336430FEE72BD9E-806B
Address 19: CAN Gateway (J533)       Labels:| 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AG    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5423
   Serial number: 28112010522144
   Coding: 030100044F05730000000058000F00010001070000000000000000000000
   GVL: 01443C0000000100400080008000480000000000000000000000000000000000
   ASAM Dataset: EV_GatewNF 013026
   ROD: EV_GatewNF_VW27.rod
   VCID: 74B1D14C4E327D7BFFA-8021
   Generator:
   Component: 5-00-11-00-04
   Multifunction steering wheel control module:
   Subsystem 2 - Part No SW: 3G0 959 442 N    HW: 3G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-PR6  H07 0110
   Serial number: PR6-0440071333204452
   Coding: 2C0D00
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 7E0 915 181 N    HW: 7E0 915 181 N
   Component: J367-BDMConti  H03 1052
   Serial number: 7734330100201126044F
2 Faults Found:
131632 - High Beam Assistant Control Module
          U1070 00 [009] - No Communication
          [Timeout Knoten 0x30 / 20 - Steuerger‰t f¸r Fernlichtassistent]
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 7544 km
                    Date: 2022.11.18
                    Time: 05:08:43
                    Terminal 30 power supply: 12.1 V
                    Terminal 15: On
8526361 - LV Energy Management
          B1802 F1 [009] - Warning Triggered
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 126
                    Mileage: 7544 km
                    Date: 2022.11.18
                    Time: 05:08:43
                    Terminal 15: On
Address 20: High Beam Assist. (J844)       Labels:| 8S0-857-511.clb
   Part No SW: 7E0 857 511 G    HW: 7E0 857 511 E
   Component: FLA           H10 0003
   Revision: AA001001
   Coding: 0000000000000000000000
   ASAM Dataset: EV_HighBeamAssisAU316 001004
   ROD: EV_HighBeamAssisAU316.rod
   VCID: 2E050324E09E17AB49E-807B
6 Faults Found:
13238273 - Databus
          U1121 00 [009] - Missing Message
          [ECU for steering wheel electronics: no signal/no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
                    Communication status of data bus 1-ABS Control Module: No communication
                    Communication status of data bus 1-Data Bus On Board Diagnostic Interface: No communication
                    Communication status of data bus 1-Engine Control Module: No communication
                    Communication status of data bus 1-Vehicle Electrical System Control Module: No communication
                    Communication status of data bus 1-Steering column electronic systems control module: No communication
13238274 - Databus
          [Diagnostic interface for data bus (Gateway): no signal/no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238275 - Databus
          [ECU for engine: no signal/no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238276 - Databus
          [Break-ECU: no signal/no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238277 - Databus
          [ECU for power supply: no signal/no communication]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
15466752 - Control module not coded
          U1013 00 [009] - -
          [ECU not coded]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
Address 44: Steering Assist (J500)       Labels:| 2N0-909-143.clb
   Part No SW: 7LA 909 144 F    HW: 7LA 909 144 D
   Component: EPS_MQB_ZFLS  751 7150
   Coding: 0106
   ASAM Dataset: EV_SteerAssisMNB 002012
   ROD: EV_SteerAssisMNB.rod
   VCID: 45D75C885528B4F3984-8011
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
   Part No SW: 3CN 035 869 A    HW: 3CN 035 869 A
   Component: MU-E-D-ER     720 0890
   Serial number: 04122000022583
   Coding: 066401003C00000041110101008000001F0000C60000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001044
   ROD: EV_MUEnt4CGen2LGE_VW27.rod
   VCID: 44D1418C5E128DFB8FA-8011
Address 75: Telematics (J949)       Labels:* None
   Part No SW: 5WA 035 282     HW: 5WA 035 282
   Component: OCUGen3Low    H14 0083
   Serial number: 0000000008NVDN2
   Coding: 06462000196818208005460160000607
   ASAM Dataset: EV_OCUGen3Low 002036
   ROD: EV_OCUGen3Low_002_VW27.rod
   VCID: 015F8898018058D3E4C-8055
1 Fault Found:
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Multi Function Display (0x0F) - Funktionseinschr‰nkung wegen Kommunikationfehler - BapErr_RetryNotSuccessful]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 40
                    Mileage: 7544 km
                    Date: 2022.11.18
                    Time: 05:08:46
                    Voltage terminal 30: 12.1 V
End----------(Elapsed Time: 01:24, VBatt start/end: 12.4V/12.3V)-----------
EDIT: posting was scrambled inside the quote
That's an interesting one. The above is gateway's view who should be on the CANbus(es). I guess the HBA is now listed in the gateway's installation list thus gateway knows whom to look for.
Anyways, VCDS uses the gateway installation list to access each of the controllers ("directly" but still via Gateway) thus the HBA is actually found being able to manifest it's dissatisfaction (below) - however, possibly on "wrong" CANbus to communicate properly with the rest of the vehicle - see further down comparison between T6 and T6.1 software identifiers.
Code:
   Revision: AA001001
6 Faults Found:
13238273 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238274 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238275 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238276 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
13238277 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 0
          U1013 00 [009] - -
          [ECU not coded]
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 1
                    Reset counter: 0
Per wiring diagram on T6 the HBA is on CANbus named as "Dash panel insert CAN bus"
On T6.1 the HBA is connects to "CAN bus extended".
First/easy/only thing to try would be to code the HBA with a proper coding to see if it's just a configuration issue in the HBA.
From VCDS main screen > Select (control module) > (Installed tab) > Select 20-High Beam Assist > Coding.... copy and paste the coding from below - click Do it!
T6 MY16-MY19 with HBA (RHD):​
Address 20: High Beam Assist. (J844) Labels:| 8S0-857-511.clb​
Part No SW: 7E0 857 511 F HW: 7E0 857 511 C​
Component: FLA H10 0003​
Revision: AA001001​
Coding: 040401E200000100000000​
T6.1 retrofit by JamesWebb​
Part No SW: 7E0 857 511 G HW: 7E0 857 511 E​
Revision: AA001001​
Coding: 0000000000000000000000 = not coded
T6.1 with factory installed HBA (RHD):​
Address 20: High Beam Assist. (J844) Labels:* None​
Part No SW: 565 857 511 B HW: 7E0 857 511 C​
Component: FLA H10 0010​
Revision: AA001001​
Anyways, I'm afraid the coding won't solve the problem as the actual HBA software seems to be different on
T6 7E0 857 511 F
T6.1 565 857 511 B
Thus possibly the T6 software just doesn't work on T6.1 - because of different CANbus configurations.
