I managed to dunk the bottom half of my iPhone 6 in a hot tub and the screen went funny and the button and bottom of the touch screen stopped working. So I had to relearn how to use it without those functioning! Not easy but gradually most of the function came back.The key blade and passive immobiliser chip should work as they’re glass encased RFID chips. The remote may be slightly sketchy though as the surface mount components don’t like the combination of water, soap and agitation.
I’ve fixed a Nokia 3110 that was under the sea for some time off Southsea pier. Just needed a new screen and the boards/connectors cleaned, but I’ve tried to fix an iPhone that had been on a wash cycle and that was well dead. Used a few bits as spares and that’s it.
Tumble dryerI have put mine through from my work shorts.
Still worked after I put it in the airing cupboard.
However my girlfriend did the same the following week and it no longer works.
I'm open to ideas...
Tumble dryer
TBH, I thought the battery or the battery terminals would be a issue (I assume they have abutton battery in) but no one has mentioned the batteries as a weak point. It could be worth trying though
I think the airing cupboard is a safer option! For the keys and your tumble dryerOh thanks. I'll whack it in the dryer after work
Keep you all posted
Yes, this worked with my phoneWouldn't uncooked rice work to draw out the moisture (like phones) or is that a big myth
I voted it would still work, because you put it on the MIXED wash !!I’ve just realised I have put my keys in the washing machine!
Who reckons they will still work when they come out?View attachment 67530
that's why i am here, hoping to find a solutio. no they do not work even after being in my pocket on a kayak 1 hr cruise. the second key went in washing machine and also do not work. so be carefull with the keys and water. they do not do well together.I am pleased they didn’t get a wash but there is a part of me that really wants to know if they would have worked after but not enough to put it in there on purpose!
