Typical central lock fault
tomek12
Hi I've notice lot people have similar problem with central lock.
So I've too .
I've done scan:
Code:
Address 09: Cent. Elect. (J519)       Labels: 7H0-937-08x-09.clb
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 069151527
   Coding: A0B4793A0AE13411922848106C2B8CDC0080632F60840000320000000800
   Shop #: WSC 02739 790 12345
   VCID: 4182EDE8D889CB49A6-8014
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU004031550635773
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU005031550643777
   Coding: 0000A0
   Subsystem 3 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 5 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 6 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TK6  H07 0023
   Serial number: 70000000000000876347
   Coding: E20000
3 Faults Found:
03301 - Response Closing Status of Drivers Door
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 2
                    Fault Frequency: 15
                    Reset counter: 56
                    Time Indication: 0
03302 - Response Closing Status of Passenger's Door
             Freeze Frame:
                    Fault Status: 01101000
                    Fault Priority: 2
                    Fault Frequency: 174
                    Reset counter: 30
                    Mileage: 92362 km
                    Time Indication: 0
                    Date: 2016.08.10
                    Time: 11:57:32
03303 - Response Closing Status of Rear Left Door
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 30
                    Mileage: 92362 km
                    Time Indication: 0
                    Date: 2016.08.10
                    Time: 11:57:32
Passenger door lock dont work like should.
I presume actuator micro switch is faulty. Central lock works fine(locking all doors) but sometimes playing up so when I open passenger door interior light on or sometime dont.
All rest doors ok.
I think have to get new lock. Or may be somethink else I should check?
I’ve just had the same/similar where passenger door lock made a grinding noise and was popping locked/unlocked (I used Carista and turned off auto lock).
After a day or two the lock stopped grinding altogether so had the central locking module replaced under the all-in warranty.
Twats didn’t put my van back together correctly and left the Bowden cable off I reckon as the door can’t be opened from the inside and I’m not fixing it for them so it’ll need another visit.
