Hello
Can any one shed Light on my latest scan Please,
i have deleted alot, and also i had 3 HVac faults wich i used VCDS to calibrate them out . the Dash board version of calibrated didnt work
I have been reading The EGR one is nothing , Correct and leave as is
the rear left door ,, does this mean Barn doors, my caravelle has a tailgate.
any help please
Code:
Friday,23,June,2023,18:15:20:49226
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4631.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: License Plate:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 15 17 18 19 25 5F 61 69 78 0B
VIN: Mileage: 121550km-75527miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
0D-Slide Door, Left -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
18-Aux. Heat -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
69-Trailer -- Status: OK 0000
78-Slide Door, Right -- Status: OK 0000
Address 01: Engine (2D2D2-CXFA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KH HW: 04L 907 445
Component: R4 2.0l TDI H02 6184
Revision: 23002001
Coding: 0025401C432401080000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KH 004013
ROD: EV_ECM20TDI03004L906056KF.rod
VCID: 7DA7EA3FDD7D6A4264D-8028
VINID: 9E60AAAAA1D8A976001C60C51028E4A72C
1 Fault Found:
15560 - EGR Sensor 1
P046C 00 [108] - Implausible Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 121547 km
Date: 2086.01.00
Time: 22:29:33
Engine RPM: 0.00 /min
Normed load value: 0.0 %
Vehicle speed: 0 km/h
Coolant temperature: 35 °C
Intake air temperature: 22 °C
Ambient air pressure: 1010 mbar
Voltage terminal 30: 12.593 V
Unlearning counter according OBD: 40
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Exhaust recirc.valve 1 bank 1: posit.feedback - Specified value: 4.34 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Actual value: 4.17 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Offset closed: 0.00 %
Exhaust recirc.valve 1 bank 1: posit.feedback - Raw voltage: 2.499 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Cooling mode stop: 2.298 V
EGR vacuum regulator solenoid valve 1 bank 1: res. Bypass operation stop: 2.560 V
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 A HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5206
Revision: 00H11V01 CVN: 5095CC72
Coding: 0014
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 34310F1BAEB76B0ADB3-8060
No fault code found.
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 43225000000626
Coding: 307E4098256984840C78027BA48621D3790000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDB503797F1B852361-806A
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 18111513470434
Coding: 01
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA5ED33D07B715A7D7-802A
Address 08: Auto HVAC (J255) Labels:| 7E5-907-040.clb
Part No SW: 7E0 907 040 M HW: 7E0 907 040 M
Component: ClimatronicT5 H03 0509
Revision: 00001K03
Coding: 0004000103
ASAM Dataset: EV_ClimatronicT5 A01003
ROD: EV_ClimaAutoT5Basis.rod
VCID: 2D071A7F4D9D3AC294D-8078
Slave 1:
Subsystem 1 - Part No SW: 7E5 907 049 C HW: 7E5 907 049 C
Component: Heckbedienung H11 0303
Serial number: BHB-0012102170015099
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 328150753
Coding: B9F679BA4AE1349393288F447EEB9EFCCDA4698960CC6960320403BF0840
Shop #: WSC 37997 001 104857
VCID: 6889AB6BA27FDFEAA7B-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 271115 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 L HW: 7E0 959 801 L Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU004111553088672
Coding: 1400B3
Subsystem 3 - Part No SW: 7E0 959 802 L HW: 7E0 959 802 L Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU018111553225290
Coding: 0400A3
Subsystem 4 - Part No: 7E1 951 171
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 171
Coding: 000000
Subsystem 7 - Part No SW: 7E0 959 442 HW: 7E0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29150002321250065473
Coding: B0FFFF
1 Fault Found:
03303 - Response Closing Status of Rear Left Door
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 193
Mileage: 121551 km
Time Indication: 0
Date: 2017.11.13
Time: 08:21:47
Address 0D: Slide Door, Left Labels: Redir Fail!
Part No: 7E0 959 243 D
Component: Schiebetuer-SG 407 0328
Shop #: WSC 02737 790 00000
VCID: 3039030B562F572ABFB-8064
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 S HW: 7N0 919 475
Component: PARKHILFE 8K H06 0210
Revision: -------- Serial number: 28261530802476
Coding: 118109
ASAM Dataset: EV_VW75XParkAssis8K 001011
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 42DD59C3E403D5BA59F-8016
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 E HW: 7E0 959 655 E
Component: VW10Airbag00C 008 0016
Revision: -------- Serial number: 003PJ000X576 Dataset Number: 7E0003V____ 0745
Coding: 000000000000000000000000000000003043
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 38293B2BB2DF8F6AF7B-806C
Crash sensor for side airbag: driver side:
Serial number: 3495ZRB40633FSTQN9J1
Front Passenger's Side Airbag Crash Sensor:
Serial number: 3505ZRB40693FGI6OOKG
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 980 L HW: 7E0 920 980 L
Component: KOMBI H05 1008
Serial number: 00000000000000
Coding: 770F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
Address 18: Aux. Heat (J364) Labels:| 7E0-963-27X-18.clb
Part No SW: 7E0 963 273 HW: 7E0 963 273
Component: STH-T5GP2 002 0007
Coding: 4101
ASAM Dataset: EV_AuxilParkiHeateWOST5G2 001010
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 6A8DD163BCF3EDFAB1F-803E
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042307
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2R8050994 Dataset Number: 5K7CV1v____ 0001
Coding: 06570001FF00000011111101008808031F0102C6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 211FF64F0145EEA2205-8074
Data carrier:
Subsystem 1 - Part No SW: 3G0 919 866 M HW: -----------
Component: ECE 2016 --- 0521
Serial number: --------------------
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 62317356001261047826
Address 69: Trailer (J345) Labels:. 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 3039030B5A2F572ABFB-8064
Address 78: Slide Door, Right Labels: Redir Fail!
End----------(Elapsed Time: 02:04, VBatt start/end: 12.0V/12.0V)-----------
any help please
