Tow Bar Electrics in way of swivel base
BlueVanMan
Hi
Just started on the conversion project - first task to swap the single seat in the front for a double on a kirivans swivel base.
Single seat out no problem.
First problem I noticed - not enough bolts for the new double seat - but think I've got that sorted.
Next problem (sorry challenge!) - hiding all the electrics away so the base plate can fit flush against the floor.
Would have been easy enough if it was just the standard electrics however just discovered that is were they had also mounted the towbar electrics. Unfortunately it doesn't quite stretch to fit under the drivers seat - that was the plan as just can't seem to find an area anywhere else big enough to store the Westfalia Junction Box (not the smallest).
So question for anyone electrically minded - is it possible to get an extension lead to lengthen the ends of the cables? A couple of Male/Female adapters and I could probably do it - but after a quick unsuccessful search on google - hoping someone might have an idea.
