Oil level low/high visit dealer my T6.1 just developed this issue i know its fine and its a fault with sensor or something are the dealers able to rectify now ??
Yes I had the same on my 18Plate van this year.
Cable underneath wore through & snapped on the chassis got it replaced / fixed by a good auto electrician in Rainham kent. £230.
Long overdue update on mine. As well as replacing the ECU ( no reason given by VW ) and the oil sensor, it turned out to be a wiring loom, which was fixed.
Got the same with my 20 plt. Vw said poss egr or software. Egr company said it was fine but sensor was reading 70mm when should be 30mm. Was intermittent, now constant. Do want to update as have a remap on it
Thanks all for pointing me towards fox/rodent damage! Allowed me to very quickly find the cable and come to the same conclusion. Easy fix.
Also took the advice on turning it into barbed wire, with sharp cable ties.
