From what research I did there are 2 ways depending which model you have.Cut the nipple ? Is there an easily accessible take off ?
Yes, see the page 1 of this thread, and there are photos of what the nipple looks like, and the connection you need for it.Cut the nipple ? Is there an easily accessible take off ?
You'll find a couple of wires where the coin is under the carpet. Set Belt Tensioner wires if I recall!So I have made some progress and have a final question about where go through the floor with the hot air outlet.
Dropping the tank and connecting the fuel nipple was a straight forward job.
Next is mounting the bracket in place with rivet nuts and then the tricky part.
My plan is to drill trough the floor inside that square hole where people also go through the B pillar. I intend to come up next to the bench where the coin is.
Is this possible or is that somehow a stupid idea? I won't know until I start drilling a pilot hole what I find there.
Thanks for the heads up.You'll find a couple of wires where the coin is under the carpet. Set Belt Tensioner wires if I recall!
Thank you all, good advice. Will get ready to fit the pipe and as I'm probably fitting an autoterm, I've ordered the angled connector mentioned earlier. Looking back thru the conversation, it looks like I'll also need a piece of rubber hose between the connector and the fuel pipe and a couple of spring band clips/jubilee clips? I don't have anything like that, would you happen to know best sizes I need to look out for?You’d need the right angle connector and a length of fuel pipe to wherever you were planning on putting the pump. I clipped mine to the OEM location along side the tank and fitted the pump somewhere near the front passenger seat if I recall.
Dropping the tank was the easy part for me (30 min work) and you get the fuel pipe with the kit so maybe wait and save a few quid?
2m of pukka pipe is only a couple of £ ( £10 for 8m ) so do it now! If you fit the heater now you can work in a warm van whilst converting it.
So my 70 plate didn't have the sacred nipple and I didn't have a stand pipe to fit, so will get this all done later in the year, possibly at a shop. I therefore have the angled connector and 5m of fuel line, rubber connector and clamps from Autoterm for sale at cost, if anyone doing/thinking the same!Hi, I don't want to buy my heater just yet as I'm still converting & wouldn't need to use it until later this year but I'm soon to be dropping the fuel tank enough to remove my Kombi seat brackets (btw anyone know the size of a suitable bolt to fill these holes back up please?)
As I have a 6.1, if I do see the nipple at this point it would make sense to fit what I can then? I can see I need the elbow connector but what else could I connect to that in order to just carry on from there another time, without messing with the fuel tank & covers again?
If I could get as far as fitting the fuel line along the tank clips, as far as where the pump would evetually be fitted, I could tie up the fuel line and put a plug/clamp in the end?
Sound feasible?
Hi @MarcLI dropped the tank on my 2021 T6.1 (Startline with Business Pack) yesterday and it didn't have the nipple unfortunately.
