Hi everyone.
I bought a 2011 T5 a on an auction a long while ago with a "small engine problem, probably the injectors". It has done 220K km. Worst purchase of my life
It wouldn't run when I bought it. Had been sitting for a while. After some disassembly I found that the HPFP had sent shavings into the injectors. It has now had the fuel system cleaned, HPFP and injectors replaced (and coded).
Now it starts right up,
but when it runs it knocks
. Here is the video. The intake is off to eliminate turbo/EGR, and the aux. belt is off to eliminate AC compressor, power steering pump and alternator.
What do you guys think? I'm a bit at wits end with this van. Not sure if it's worth it to put in a reconditioned engine (especially without pinpointing the cause) but I've already spent $$ on the HPFP and injectors.
I count roughly 15 taps per second which corresponds to the idle speed of roughly 900 rpm. So one tap every revolution. Then it should not be from the camshafts as those spin at half the crank speed?
Thanks and best regards
- When I had the injectors/HPFP out I took off the valve cover. It looked clean.
- When I replaced the HPFP I changed the timing belt. The old one was still in time, and had previously been replaced at the right interval (but was again due)
- No (engine) fault codes in VCDS. I did the "compression test" in VCDS and the result was even over all the cylinders.
- No smoke from the exhaust, combustion seems clean. Oil filter doesn't look abnormal, can't see any metal flakes. Not much blowby either.
- No service history. Since there was no "sludge" in the top end and the timing belt was replaced on time I think it has had a decent level of maintenance.
- Noise coming from the conrod bearings (new engine?)
- Noise coming from the valvetrain (new head?)
- Noise coming from the clutch/flywheel, which was supposedly replaced 20K km before I bought the van (no change in noise with clutch in or out).
