lukaspun
Hi all,
I’m trying to figure out a persistent squeaking noise on cold start with my T6.1 (2020).
The timing belt had to be replaced quite early at 65,000 km (40,000 miles) due to what the dealer said was a known issue on this model. Since the replacement, there has been a cyclic squeaking noise during cold starts.
They then replaced the belt tensioner under warranty, but the squeaking is still present on cold start.
The sound appears:
Has anyone experienced something similar after a timing belt replacement on a T6/T6.1?
Any ideas what could cause it or what I should ask the dealer to specifically check?
The sound appears:
- Right after startup when the engine is cold
- Lasts briefly while the engine is running
- Sometimes disappears after a short time as the engine warms up
