I'm about to swap my lead acid battery out for a Super B Epsilon Lithium battery. We spend a fair amount of time "Stealthing" it both winter & summer, and the current 110ah battery is getting tired & isn't up to the job anymore. This is our current setup:-
1, 110ah Lead acid under passenger seat
2, 130 W solar panel
3, 15 A mains charger under drivers seat to charge the leisure battery when on EHU.
4, Ctek Dual250 b2b under the passenger seat by the battery, this handles the Solar & B2B charging.
5, Ctek "Stop Start" charger under drivers seat, this is connected to the starter battery to keep it charged when parked up for long periods.
I'm proposing the following changes:-
1, SuperB Epsilon 90ah Lithium battery with built in BMS & Bluetoooth.
2, Ablemail AMS 12-12-30 reprogrammed with a Lithium charging profile, this will replace the Ctek Dual. AMS12-12-30 | 0161 745 7697
3, A mains charger around 15A that will charge Lithium, open to suggestions, but I'm trying to get away from cooling fans if poss. Victron do one with a "Night time" setting to reduce the fan noise. Can't see that Ablemail do one.
4, Keep the Ctek "Stop Start" charger.
One thing that occurs to me looking at the Ablemail, is that the ignition sense comes off the van battery to start the Ablemail charger. If I have the Ctek "stop start" connected, will the Ablemail see this as the engine running & try to draw current from the van battery/charger combo? I would have thought that the "Sense" line would be from an ignition controlled source.
Do Ablemail make a mains charger?
Any thoughts?
Any thoughts?
