For Sale Standalone ESP32 BLE Battery Display for Victron Systems
It's just the button that's the main issue for me.
I've had the device apart, by heating the screen it melts the glue, you can use a suction pad to separate the screen from the casing. Be careful, the antenna is connected.
When I get some time I was going to try and make a button that could be held internally of the case, and facilitate pressing the button too.
If you planning on making a case ect will you be selling these? Or just creating the STL file so people can print these themselves?
Reason I ask is that I currently don’t have a 3d printer and have to rely on a friend to print. Either or I’d defo be interested.
Can I just add if you are going to print design these ect please made it so we don’t have to take the current screen apart to fit them as knowing my luck ill damage the screen or something.
That’s handy to know, do you need to remove the current case from the screen or do you simply just drop the current seen and case into the new printed case with the buttons.
Currently at work and not tried it but the internal diameter of the printed file is approx 38mm (1 1/2")
I received my screen today and by lord it’s impressive!
Tested the Fogstar and the % don’t match up to what is state on the app or the shunt.
On the shunt screen it state usage but shows me the temp, not sure how to add picture as I’m a new member sorry
Please can you make a ble capture near to the battery, and send it across to [email protected]
Sounds like something I need to fix in the firmware. Also send across screenshots of your frogstar app showing what it should show, so I can tally up the readings.
No problem at all, please don’t take this as a negative as iv very very pleased with my purchase
I’ll send the photos over via DM as I’ll send a link to the photos
