The screen would be the expensive part
Wiring it in a factory way (BCM controlled) is possible, would require a bit of fiddling in the dash to get it all connected and would need the dash button added etc but if you are up for it im happy to go through it with you and make up the wiring etc ??
Let me know if you are interested and i will price it up
Can you not claim on your insurance for screen ??[/Q
Pauly - just had a retrofit screen added to my van. Just need to wire it up somehow? Any help appreciated ??
If you find one please let me know!Thanks for your reply, cost wise that sounds fine, just need to find a company than can do this
don't waste your time trying to get a oem screen they are probably more prone t breaking than a auto glass replacement.I' waiting for autoglass to come back to me as I told them I wanted a genuine VW one fitted and they don' know if the insurance will pay the difference. So I doubt they would let me get a heated one put in?
Ok so I don’t have that switch on my OH T6 caravelle Executive because somehow it did not have a heated screen fitted, can it be retrofittedBy the way, I will join the thread, because I damaged the glass and replaced it immediately with the version with heating. A few photos from the process of creating a cable harness. I already had a switch for heating the windshield integrated in the Climatronic panel. The description is for the T6 version, not the T6.1 version, but the cable harness is the same. As the work progresses, I will try to include the remaining stages of assembly.
Below, a part of the cable harness - ground wires. The photo also shows the part numbers - plugs.
The end of the positive cable. I needed two of them.
The connectors I used should be sealed.
Ground point under the wiper mechanism to which we attach the cable harness.
Connection to the windscreen strips. The external is positive, internal is mass.
I just don't know if these windscreen tapes should not be hooked somehow, can someone give a photo of how it's made at the factory?
