Ply floor and insulation installation
Thread resurrection - sorry...
I'm just preparing to carry out floor insulation and lining in my van so this is all good info. I'll do as @Superowls and packer with 9mm and silent coat all the gaps.
Just looking at those packer kits and the price is way up - now £45 +VAT for a kit, and they're on back order. It would be interesting to know the total area of ply needed - since an 8x4 sheet is £24 from B&Q (and that's going to be way more than needed).
My plan is - 9mm ply packers - 2mm silent coat on the remaining exposed metal - 9mm ply floor (since I've already got) - and Altro floor on the top.
Hopefully a Kombi step covers that?
Sounds like a plan.
My Kombi step & rear threshold fitted straight over no probs
If you're happy cutting up the ply then you might as well do it yourself and save a few quid
I did mine in October so didn't fancy a day on the drive measuring, cutting & sweeping up so was happy to pay the extra for the convenience
Just weight them down overnight after you've stuck them to make sure you've got a solid base to screw the ply floor to
If I put down silentcoat everywhere on the floor and over that the 12mm ply board why not just attach the whole thing with the six mounting points for the brackets? Why even bother with the battons and sika?
i fixed my ply down with counter sunk machine screws using the tie down fixing points. You will still need 9mm ply Packers though as the ribs on the floor aren't all level
Hi I'm interested to know how you got on as I'm at the same stage.
I've 9mm batons with dodo deadn hex over the metal floor. I plan to put the 9mm floor that came in van back down.
Did you use insulation and how did you attach ply to batons adhesive or screws?
I have an altro liner to go on top of ply. I have enough thermal acoustic foam left over to cover floor but worried it might raise floor too much for the combi step.
I like this idea. I appreciate it was a long time ago, but can you remember what length screws you used?
IMO insulating the floor could cause issues with retained moisture, it’s the lowest point so any condensation elsewhere may find it’s way down and any spills or leaks could end up under the floor. Water in that area could result in delaminated plywood and possible floor replacement.
I have 2mm silent coat, ply and Altro floor, the Altro surface is cold in winter even with a Diesel heater but I’m not sat in the van with my bare feet on the floor.
How easy was it glueing the altro to the ply?
What's the general consensus on sound deadening and insulating the floor.
Is it necessary?
1 or the other?
Is it necessary?
1 or the other?
I can only answer from my experience. Sound deadening not worth much as there are not many big flat areas, so you add weight for little benefit. Insulation is worth it - my floor has an XPS laminate layer included.
Other folks will have a different view though.
Is it necessary?
1 or the other?
There probably isn't a general consensus. I didn't insulate or sound deaden the floor.
There's 12mm ply and vinyl flooring that will be providing some sound deadening and insulating. We only really use the van in summer, and it's often warm enough just with side wall and door insulation that we end up opening a window for the night.
If I was using the van in winter and had a heater installed, I'd insulate the floor.
Down to personal preference and what you intend to use the van for I guess.
Sorry for resurrecting the thread.
If I cover the floor with 10 mm thermal insulation (Armaflex, kind of XPE material) and then put the standard 9 mm floor from panel van - will the kombi step fit?
Also I've found this step:
And this threshold:
Any ideas if they fit?
Another floor question. I’m have a plyguys installation in August but am fitting my own floor. Their website suggests fitting a ply floor over the vw soft rubber floor and securing with the lashing points as an alternative to gluing batons and insulating over.
Since I have the soft floor, and have sourced a 1 piece 12mm ply floor I’m considering this as an option. Any thoughts?
I have a carpet currently which I’ll remove when I fit my floor… mainly due to concerns it will retain any moisture and go mouldy…
I also have a sourced a 1-piece floor and am going to trial just securing via lashing points first… if that’s secure enough I may not bother bonding down
