Hi,
Quick back story; recently had my CFCA rebuilt, popped it back in the van and had an oil pressure issue. Drove spot on but occasionally flashed up about the oil pressure when hot. Engine came back out and went back to the builders to change the oil pump.
Oil pressure is now spot on but I have a different issue with too high fuel pressure. The only thing I changed was the leak down pipe (for an aftermarket jobbie) as I broke one of the connectors.
Is this likely to be the issue? Shall I swap over the (presumed) non return valve which looks a lot smaller on the aftermarket item?
I have VCDS and can see the rail pressure is higher than the expected value.
The van idles fine but won’t rev over 2k ish unless you work up to it slowly, if you give it some stick it’s like it hits a wall.
Any help with VCDS would be great before I throw the parts cannon at it!
