T5.1 oil pressure warning light
samtj89
Driving my van on a 160 mile trip after about 50 miles the red oil pressure light came on for a few seconds and then went out again. Pulled over and checked everything seemed ok. Continued drive home and then the light came on for a second again right at the end of my journey i plugged in vcds with no faults active or stored. Im hoping this is just a sensor fault its a 2012 with the 2.0ltr caab engine code. Has anyone else experienced any issues like this before?
Im going to plumb in a oil pressure gauge to monitor the oil pressure before i get too carried away with anything. I wanted to remove the high pressure oil pressure switch but i can seem to see one located on the oil filter housing. Is there anywhere else this could be located
Cheers sam
caab engine code
CAAB engine has only one oil pressure switch. It's located in cylinder head (behind).
Details in
