Yes it does mate. Just curious though......if you used a genuine vw oil filter....how would anyone know you'd changed the oil?If you pull the filter 1st the oil is dumped into the sump,so as long as you do it before replacing the sump plug i wouldn't worry.
The sump plug on mine eruo5 140 is a metal one.
The reason for me to use the suction pump was to try and keep everything the same as it left the factory (probably being a bit daft) so that when it goes in for its first service they won't know that I have changed the oil myself.
I found it a very clean job and the suction pump pulled exactly 7 ltrs which is what mine holds
Hope this helps
Why should it matter if you change the oil and filter your self, providing you use VW Genuine oil & filter ?Yes it does mate. Just curious though......if you used a genuine vw oil filter....how would anyone know you'd changed the oil?
FYI - It looks like I am mistaken, this is filter is for the DSG box, thought it was to easy! can't see the bloody oil filterThe oil filter on my T6 150 dsg is at the rear of the motor on R/H/S should be able to get at it from the top no problems...24mm socket View attachment 9088 View attachment 9089
I was just looking at the instructions for the oil and filter change. Mine's a 150 manual.....not sure of engine code. I'll be doing mine at 10,000 miles as I too will probably have mine a long time.....certainly 5 years. Anyway, I noticed that you have to remove the oil filter BEFORE draining the oil.
1) Does this sequence actually matter from a technical standpoint......is it just to reduce the chance of dropping oil on the ground as it mentions a valve opening on removal?
2) Is the sump plug plastic......if so maybe it wouldn't be a bad idea to stock them in the shop......or does everyone use one of those suction devices these days....are we going away from dropping the oil via a sump plug????
3) Am I a dinosaur......using a suction device doesn't seem as effective in removing ALL the old oil......surely removing the sump plug is more effective???? I'm more than happy to be corrected and dragged into the 21st century on this one!!
I just get the feeling even a bloomin oil change is a lot more involved now!
Thanks guys.
MD
Welcome Gooral! Can I take it yours is a DSG? On the manual, you have to remove the underbody tray......8 bolts if I remember rightly and dead easy. I was tempted by one of those suction devices but decided it would leave crappy oil in the bottom of the sump so didn't bother. For me, it's gotta be sump plug out and filter off.....I have to admit, as simple jobs go....from start to finish, it was the most time consuming oil change I've ever done....hey ho. Castrol Edge at 30e/4l in Poland......b*ggar me......is anyone off to Poland anytime soon??Just changed oil on my van. Failed to find oil filter (i really miss my 2k caddy for ease of access). So decided to change oil only (it is a first change- i have done 9k km in 2 months - originally planned to change it even earlier but was too busy).
Luckily i had 2x4l and 3x 1l bottles of oil lying around (not expected it to hold 7l+ i was up for real surpriseI don't know when my next (well first official one) service is (f$""£n flexible service according to sticker in manual and 30k miles according to sticker on sunvisor) but i guess it made no harm to replace oil only (far from perfect though - if knew that i will need more than 4l of oil i would replace filter for sure). I tried to push that button on dash board to get to service interval menu as mentioned in manual but i failed to get past setting time.
I think as someone said that sequence for filter first is mentioned only to make sure that you get rid of all old oil before replacing it with new one.
Sump on my one was 19mm metal bolt.
In my caddy suction device would leave at least half a glass of oil in the sump so i used in only twice - first and last time.
Ps if i to pay irish prices for oils (castrol edge in halfords 60e/4l and i think i saw it for nearly 80 somewhere else) it would make no sense to replace it by myself (vw wants 200euro for replacing oil vs roughly around 150 i would have to pay for parts only).
Castrol edge in Poland is closer to 30e/4l.
Welcome Gooral! Can I take it yours is a DSG? On the manual, you have to remove the underbody tray......8 bolts if I remember rightly and dead easy. I was tempted by one of those suction devices but decided it would leave crappy oil in the bottom of the sump so didn't bother. For me, it's gotta be sump plug out and filter off.....I have to admit, as simple jobs go....from start to finish, it was the most time consuming oil change I've ever done....hey ho. Castrol Edge at 30e/4l in Poland......b*ggar me......is anyone off to Poland anytime soon??![]()
