Hi i have a T6 2017 DSG
It has an oil leak around the oil filter housing when i park up any it leaves a little pool of oil.
At least thats where i think it is coming from
As there was a problem with the van not long after i brought it, so it went back to the garage where i got it from and was...
Service Parts List - What Goes Where -
Here is a Basic list for all Parts required for Servicing which will be updated moving forwards:
Brakes:
Pads:
308mm F Pagid Brake Pad (Front Axle) Product Code: 101441298
340mm F Pagid Pagid Brake Pad (Front Axle)Product Code: 101441868
340mm F...
Hi all I had a dpf recall so wanted to change the fuel filter oil and oil filter. I used the parts guide finder from this site but the fuel filter is the wrong not sure yet about oil filter.would anyone be able to help.i phoned vw but they would not give me part numbers
Can anyone confirm that the Oil filter is only accessible from underneath the engine after tray removal and that the Drain plug is made of plastic?
Any photo`s?
