Hello all. I have a T28 6.1
It already had 6mm ply flooring down (looks CNC cut) when I bought it.
I will be bolting the units to the flooring.
I have two options, use the 6mm ply, and add 9mm ply batons glued under the 6mm ply (between the metal grooves) for extra strength where the units are going to sit.
or buy some 12mm ply.
I would like to keep the 6mm mainly for the lighter weight (as the van is T28). Do you think that the 6mm will hold out ok?
