Bluemerlin
Good morning all, first post on here but have been using this forum for guidance for some time now, and thank you to @Pauly for accepting me.
So he is where I am, I’m looking to install a wired aftermarket camera from ADT and fit it to my OEM composition media head unit. However finding it difficult for guidance on such a topic, most are for oem cameras.
The camera I have is of NTSC format and I have already installed the Video feed input into the Quadblock at the rear of the headunit into pins 6 and 12 on the blue block.
The power supply I was planning on running from the quadblock also seeing as I was running the VGA anyway, pins 17 and 8 for +/- a wise idea? Reasoning behind it thought if I went to the rear reverse light, green and black/brown is it? It may not be a stable enough source due to PMW.
But the RCA video cable also has a trigger line attached, designed for aftermarket head units with a trigger output I’m guessing. this is where I’m stumped, where
Do I connect this red cable to? For oem I read there’s a white connector and pin 12 green/black is a reverse trigger, should I extend the small red line off the RCA to meet this? If so, what do I connect the other end of the RCA cable red to?
Does anyone have any insight into this that could possibly help?
I have added some pictures to try and show what I mean.
Tia
Blue.
Tia
Blue.
