Hi, the front can be adjusted by the method you’ve mentioned. The rear cannot. As for tracking that’s not required when you adjust the arb as you’re not affecting the alignment on the vehicle, just the residual tension in the arb by effectively shortening or increasing the length of the leaver by bolting to one of the 3 holes on each side. Obvs ensure you set them the same on each side.
