The bushes can wear although not as likely as the actual ball joints within the drop links.
Other than physical contact between parts of the suspension, the other common issue is that the stud that attaches the drop link to the strut can move. Either the nut (often not replaced) just comes loose or the stud is a smaller diameter than the hole. In this case, it's only of matter of time before it works loose and movement will occur.
