H7 or H4 headlamps? Differences?
Looking at the part number i believe they are standard VW H7 headlights for LHD
Just to be clear the lamp kits in the shop are not really upgrades more of a different colour, they are white lamps instead of the factory yellow and are not intended to give increased output
If you are looking for upgrade lamps you would be better looking at the +130 or +150 lamps from osram or Philips etc
eg https://www.travelvolts.net/product-page/philips-extreme-130-headlight-bulb-h4
Thanks for the info Pauly, but I thought I saw someone in another thread on this subject ( there are a lot... ) Say that the Phillips +150 don't work properly in the H4 unit? I think they generate a dash light CAN prob?
I may be wrong as I've read a lot on this in prep for me doing an upgrade.
Note to self: stop reading this forum! :)
They definitely look better than H4's! Not used them yet but pictures coming through! Thanks to @Eclipse Campers IMG-20190323-WA0020.webp
Just to be a contrarian I quite like the look of the H4 headlamp particularly the way the chrome line gets picked up from the grille to carry on into the lamp housing, I also like the huge size of the main/dip beam reflector which would look equally at home revolving at the top of a lighthouse, quite how a reflector this size performs so poorly at directing light towards the road surface is a mystery, possibly the lamp is not in the best position?
Slightly OT but is it very naughty driving on just your DRL and sidelights as having put LED lamps in the DRL socket on each light it's like driving in really strong moonlight albeit there's not so much a beam pattern as ball of shimmering white in front of the van... it's very naughty then?:oops:
The DRLs are brighter without the sidelights on :thumbsup: I must admit I think the DRLs on the H4s look better than the ones on the H7s
tried the search but keeps excluding H4 and H7!
How do I identify if my van has H4 or H7 headlights?
many thanks
Awesome cheers, knew it would he on here somewhere, apologies for being crap at the search tool
Search tags are a good feature, you can see what’s popular, and you can search by using more than just one (you’ll see them at the top of the page on this thread, for example).
See the last post on
if you want to see what I mean.
Or post a pic?
If your DRLs are large, square DRLS towards the middle of the van near the grille, then they’re H4. If they’re H7, they’re a small bar under the low beam reflector.
Alternatively, put headlights on, select main beam. H7 should give your four headlights lit. H4 will only light two.
cheers for the reply's, used the picture and took the van out for a spin, what road?? definitely H4's!! :cry:
For the short term buy some 150% brighter Bulbs from Halfords and accept there offer to fit them. Oh, take a book and some sticking plasters for the poor guy. Or just follow instruction on here somewhere!
