Fogstar Drift 12v 230Ah Seatbase battery -- "How I Done It" --
Thought I’d jump on this thread with a question rather than start a whole new thread.,
I’ve just bought the Fogstar eco 100ah
Does anyone know what state of charge they are shipped at?
Haven’t got the charger side of my set up done yet but wanted to check my lights, chargers etc work
They're sent at around 50% SOC as that's the 'storage' charge level. So plenty to check stuff is working!
Around 50%
Reactions: Sp1
Hi all,
I've just purchased a Fogstar Drift 230Ah seat base battery and have tried to fit it today. I'm really struggling to fit it beneath the passenger side of my van using a Sportscraft swivel seat base. The seat base is the version supposedly meant to accommodate a battery but to me this seems physically impossible, the battery sits higher than the base frame and the seat base has a strip of metal that fouls on the battery. I've already ground down the earth stud and trimmed back the carpet to try and lower the battery a bit, but this hasn't really made much difference. The only other thing I can think of is perhaps higher the whole base from the floor somehow, is this something anyone has done?
Today has been an extremely frustrating day, wasted loads of time on this getting nowhere.
Any suggestions before I admit defeat?
Thanks,
Mark.
Not tried fitting that battery, but had issues with my Roamer 160. The Sportscraft leisure battery swivel has an extra flat U-brace welded underneath which reduces the available height. People on here remove the underbase earth point and have it sitting on the cab floor to get it low enough. Alternately you can space between seat base and swivel. I made 10mm spacers for a previous AGM battery using threaded Hex on the front and milled spacers and longer bolts on the rear.
Thanks for this, glad to see I'm not the only person who has suffered this then! Yes that's exactly the problem, it's the U brace as well as the other angled metal running parallel to the brace that are definitely causing the issues. I did cut down the earth stud to reduce its height but I think the battery is still fouling against this - although I don't believe this will reduce the height enough to make a difference it will certainly help. If I remove the earth stud entirely are there other viable places nearby that I can run the earth wiring under the seat from?
I think realistically the spacer option is the only way this is going to work, 10mm might just about do it. It will make the seat slightly higher but I can't see any other option.
From what I can see the front bolts in the seat base are studs welded in to the base, at present these studs are considerably shorter than required to space the seat plus get a bite from the domed nut atop of the swivel base, how could I reliably extend these studs? The rear seems to be straight forward as I can just use longer bolts with spacers.
Sorry for the stupid questions!
Mark.
Ha ha yes its incredibly tight - so not a daft question at all - just the constraints of making the most of the space available in a Transporter seat base! I haven't fitted that battery, so I recommend seeing what guru @Dellmassive recommends :D Someone on the forum will have fixed this issue before
Think people have used one of the seat base bolts with sufficient prep as an earth point.
Yes agreed about the front. I cut down some threaded hex spacers If you want my (redundant) spacers PM me to sort that out, but I would sweat your design bit more to keep the seat lower overall - no idea if there is a solution mind :)
Cheers Andy
I have the RIB swivels on mine.
Assume they are similar to the Sports craft.
Got any pictures pics of the battery sitting in the seat base?
I've gone the same with the Roamer sb230, ie cut the earth stud. Trimmed the carpet. The battery JUST fits between the bottom seat rails.
But that battery could on the seat base spacer blocks under the carpet
So you can trim them down.
Or fit spacer shims ,8 or 10mm penny washers ander the swivel plate. Or below the seat base.
More info.
So the seat base looks like this:
I'm starting to think this just won't work with the fogstar base battery at all, the protrustions on this swivel base are quite extreme (this is the underneath)
The ridge at the back hits just where the battery terminals are. :-(
I'll get some pictures of the seat base sitting in place later after I get back from work.
Looks like you might have to swap them seat basis for something else?.
I had the RIB ones and it worked fine.
I'm selling a full set of rib seats swivels if you're interested?
Thanks for the offer @Dellmassive but managed to somehow sort this. It was such an incredibly tight squeeze it's a miracle it fit at all. Had to use around 5 penny washers on each seat base stud + 2 penny washers on the seat base. I also had to grind away the ground nut below where the battery sits as you had suggested. For a new ground I sanded away the paint on one of the holes where the seat studs sit to make good electrical contact, then did the same for another hole on the base where I then moved the ground connection too. This seems to have formed a reliable ground based on resistance tests and resolves that issue with a tidy finish.
This incremental addition of spacing was just enough to do the job.
Fogstar have now released the pro series that has victron integration, same as the Roma battery.
Anyone know if these dimensions will fit in a seat base?... We're traveling so not in a position to do any research or have a measure up.
They calling it day 230 amp hour drift pro model. But it's not in the same as the drift non-pro seat base model. (That I have in the van already)
Underseat dimensions 275 (L) x 315 (W) x 187.5 (H)
This battery dimensions
280 x 320 x 205 mm
The underseat battery just fits heightwise doesn’t it and possibly doesn’t fit with factory swivels. This would be 12.5mm higher
Second 230ah going in on the camper.... (Roamer, but basically the same)
400A Mega fuse for now, I'll monitor max load current s and down size fuse accordingly
