Has anyone seen the new DIN size leisure battery from Fogstar?
www.fogstar.co.uk
My standard 100Ah lead acid one is rubbish and I always suffer from battery anxiety. Assume lifepo would regulate voltage better and be more stable.
The space I have under the seat can't fit the normal generic shaped lifepo batteries without completely redoing electrics so have been looking at direct DIN replacements and the Fogstar is a direct replacement.
I have a victron 15A smart charger which I would just need to change settings on I assume. Anything else to think of? I don't have a shunt currently just the cheap BM2 which I would remove and replace with the Fogstar app.
Fogstar Drift 12V 172Ah (H8) DIN Fit
The Fogstar Drift 12V 172Ah DIN Fit is built in a standard DIN case format, designed as a direct physical replacement for traditional lead acid leisure batteries.
