Hi newish member first post so here goes. I've got an oil pressure fault implausible signal when I hit 2k revs cold and 3.3k revs warm. The van is a vw t6 2016 102 5 speed 100k. Runs sweet no noise not losing oil etc etc. I had a guy out to give dpf a chem clean as was getting dpf alarm and flashing coil. He read the codes and all resolved apart from the oil pressure alarm he advised me to replace oil pressure sensor. So I purchased 1 and the work shop manual off line. Only issue is it states its on rear of block behind lifting eye under egr. I cannot see any sensor or any connector in this location. The only place a I can see one is on the oil pump itself. Any guidance appreciated on location and procedure of replacement. Thanks in advance
