Flashing glow plug oil pressure fault
Jimmynoone79
Hi newish member first post so here goes. I've got an oil pressure fault implausible signal when I hit 2k revs cold and 3.3k revs warm. The van is a vw t6 2016 102 5 speed 100k. Runs sweet no noise not losing oil etc etc. I had a guy out to give dpf a chem clean as was getting dpf alarm and flashing coil. He read the codes and all resolved apart from the oil pressure alarm he advised me to replace oil pressure sensor. So I purchased 1 and the work shop manual off line. Only issue is it states its on rear of block behind lifting eye under egr. I cannot see any sensor or any connector in this location. The only place a I can see one is on the oil pump itself. Any guidance appreciated on location and procedure of replacement. Thanks in advance
Which 102 engine?
Either non-AdBlue engine code CAAB
or
with AdBlue engine code CXGB (code is printed on sticker by steering column under dash)
Cxgb add blue version
Yes, there are two sensors.
The other
The oil pressure switch for reduced oil pressure - F378- is located
at the rear of the cylinder head above the turbocharger. Use a
small hand mirror if necessary as it is difficult to reach.
Some related info
The other
Some related info
Magic I have something to go off tomorrow. Why do they always put these things where a small hnadmirror is needed lol
:thumbsup:
Well, the implausible signal might actually indicate faulty oil pressure regulating valve.... Quoting my own analysis/speculation:
Analysis of fault codes - to be continued...
Background
  • The fault codes do not identify low/high-pressure sensor.
  • Working hypothesis is that implausible signal (P164A) possibly points to regulating valve - the switches have only states open/closed. Thus implausible would possibly mean oil pressure switch not responding to commands of oil pressure regulating valve... (see switch (oil pressure) responses to oil pressure regulating valve in the graphs above, especially the full throtte case). TBC...
Hi, I have exactly the same problem with my van, same engine, flashing coil light at 2k and 3.5k . What was the solution for your van ? So far i've changed both oil pressure sensors and my light is still flashing, oil pressure regulator valve next ?
Hi I’m new on here
I’ve t6.1 44k
140 Bph add blue
So I’ve glow light on and code says oil pressure switch.
I’ve replaced all the switches and it’s back on again.
Any idea?
Hi I’m new on here
I’ve t6.1 44k
140 Bph add blue
Any idea?
Same happened to my van, I changed the oil pressure regulator and that solved the problem. All been ok since then.
Thanks, I’ll get on it and let you know how it goes,
Hi again,
I’ve changed all the oil pressure sensors, regulator 3 in total and it’s still flashing,
Oil pressure is good.
could it be the pump @ 44k
Don’t know where to look next
Hi again,
Did you get this sorted? Cheers
I have the alarm again. Only comes on when good at low recs. I restart the van and clears does not return. If I start the van again later in the day it’s ok. Only seems to occur when engine cold. I think this may be different issue to my original problem which was resolved with new regulator
Did you get to the bottom of this bud?
