So the story goes..
I wanted a remio multirail and an F45s (3.0m)
I didn't want to drill into the outskin of the bus, to fit the fiamma multirail bracket option.
I wanted to be able to remove and apply F45s at anytime in a timely manner (2 x bolts)
I wanted something secure, low as possible and work with the pending HiLo roof.
So I bought both VWT5/6 fiamma bracket options and set to work on a solution that solved all my issues..
Some will say the wasnt an issue, some will agree that the thought of drilling into outer skin shouldnt be nessersary.
This is my proto type; it is yet to be powder-coated..and requires a couple more soft pads on underside(hinesight) having spoken to @Davenjo @BiTurbo a middle bracket will be added, despite fiamma not providing one within their 'kit'.
With the multirail on it closes the ingress gap down to 5mm, so may not require rainguard. Time will tell, If it does require a rain guard it will be attached to the rear of cassestte into the multi rails, by being pinned down by new brackets, rubber strip (@DaveyB )..in theory..
These brackets are made with the option of adjustable height. The reason for this is different companies fit multirails at different heights. My multirail (fitted by dirtyweekenders) was too low for and the fiamma brackets made cassette catch sliding door.
The front bracket is slightly higher than the rear to allow the front door to miss the inner support arm, again sometimes this has been a known issue..
Anyway, long story that I hope to continue..
If anyone is interested any then let me know.
Fish out!.
Fish out!.
