DPF Regen, Yellow Light & Adblue - Whats It All About? -
You will have to tell me what that is and where to find it?
How-to create a blockmap file:
Ignition ON
[VCDS]
[Applications]
[Controller Channel Map]
- Single Controller Address = 01
- Login or security access code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
The result (CSV) file is saved into directory C:\Ross-Tech\VCDS\Logs
Took this photo of the VCDS on the laptop
It shows 7.992litres and 69mm
I will now attempt to transfer the block map file from my ancient laptop.
I am wondering why VCDS has said over 11 litres to just under 8 litres, still have the spanner and 500 mile countdown? Only driven the van a couple of times 27 miles on the trip.
Without knowing the level, what to do?
Is there a way of clearing the spanner/tank sign and countdown?
I have looked under the van, I can't see any leaks or a snail trail/tell tale anywhere. The filler push fit is snug.
Mrs is going to get some of the Adblue treatment stuff from Halfords today.
VCDS IDE03142 says 9466.940 km range.
I am going to draw some out
VCDS SAYS 11.81 litres
I am deffo going to try and draw some out.
Did you draw some out?
And now it’s saying, yes I know the time is wrong, but min 1gal - max 1.75gal is a new message.
So the "Error" has disappeared - a healing on the way?
Any chance to get another engine blockmap now as the error on dash is gone?
@mmi
hopefully blockmap is attached.
Thanks for your help and advice
Thank you. The level and temperature sensors work just fine. So plenty of AdBlue
Anyways, the ECU software is still as from factory - 04L906056KL 3802
My advise would be to start troubleshooting with updating the software - to version 6166 (or later) just to exclude a known software glitch on MY16-18 engines (as yours is) causing an issue which quite possibly is what you are currently experiencing.
@mmi
Thankyou
The spanner and can is still there. I reset the clock. Picture should be attached.
I didn’t draw any out because the level wasn’t consistent. Not sure that I trust the level indicator.
I did put 125ml of Wynns Adblue treatment in.
Will add block maps from laptop.
