So I’m running all the cables for the conversion and all is going well, despite always needing more cable!!
The test install of the victron kit has been successful, so now I need to put the finish panel behind and re fix it all back. The space to the right of the MPTT solar controller is for the victron Orion dc dc charger.
as you can see, I have installed a Victron 30 amp mains charger, that has its own dedicated 6 amp RCBO in the EHU consumer unit in the engine compartment battery area.
My question is, do I need to keep the 13 amp plug on the cable (has a 5 amp fuse fitted) and then have to find space for a 13 amp socket, or can I direct wire into the feed cable from the consumer unit.
Thanks in advance
Deaks
Thanks in advance
Deaks
