Solar Panel. . . 180W (24.0v VOC, 9.22A ISC) Black, Mono, rear junction.
I've asked the pop-top installer to fit the panel. . .
I've included the install guide in the panel box,
and I've highlighted the install notes about FILLING IN THE ROOF RIDGES, to create a smooth surface (for equal thermal expansion across the panel)
and I've highlighted the bonding methods,
but really I'm in there hands, ill voice my concerns about the fitting. (but they will be, weve fitted loads of panels and never had one go wrong) - but we know better.
if you have a decent quality panel from a good manufacture, them im 90% sure the failures are down to poor fitting and not following the install guide, most noticeably "filling in the roof ridges" so you have one smooth surface.
Solar panel specifications:
- Peak power: 180W
- Maximum power voltage: 20.5V
- Maximum power current: 8.79A
- Open circuit voltage: 24.0V
- Short circuit current: 9.22A
- Dimensions: 1470 x 665 x 3 mm
- Weight: 3.15 kg
This product comes with a
3 year workmanship warranty which covers material and production defects. For more information please refer to our
Terms and Conditions.
At Photonic Universe we love high quality solar products. That's why we have developed this highly durable black semi-flexible solar panel
reinforced with fibreglass plastic and a
strong ETFE surface and made from
monocrystalline solar cells. This model also features a
rear-fitted circular junction box and
3m dual core cable. This high efficiency
180W solar panel is perfect for permanent outdoor use to provide free electricity for charging 12V batteries to power various applications, such as in a motorhome, caravan, camper, boat, or for solar lighting systems, off-grid, and back up solar power systems. The panel can also be used to provide direct power supply for applications not sensitive to changes in input voltage / current (e.g. electric motors or pumps) and for various grid-tie applications.
Product features:
- Robust construction using plastic reinforced with glass fibre creates a sturdy and durable solar panel
- Special textured surface significantly reduces light reflection and improves performance in low light and cloudy conditions
- Highly flexible design makes this panel ideal for curved roofs and surfaces where bonding is preferable (though it can also be fixed by bolts or screws)
- The panel is incredibly light (only 3.15kg) and very thin (just 2mm) which is great for all vehicles
- High resistance to salt water environments makes it perfect for boats and marine applications
- Sealed waterproof design ensures it can be used in all weather conditions
- Junction box on the back allows for a smooth and level surface, free of trip hazards and unsightly cables. Round shape for easy fitting
- Fitted with a single length of high quality 3m dual core cable for easy installation and wiring
Strong ETFE coating:
In addition to the fibreglass reinforcement, the surface of this 180W semi-flexible solar panel is made of strong
ETFE material which has a longer service life compared to standard semi-flexible solar panels. As a result, these particular semi-flexible solar panels are
extremely hard-wearing and less prone to cracking, delamination and corrosion. The lightly textured coating of this panel creates an
anti-reflective surface which allows the panel to absorb a far greater amount of light, thereby increasing efficiency. ETFE material has long been used in applications where durability and high-temperature resistance is required, such as in the Eden Project, Cornwall. You can read more about ETFE and its benefits
here.
High quality 5-busbar solar cells:
This panel also features
new generation 5-busbar solar cells, which are more efficient than the 2, 3 or 4 busbar solar cells used in most other solar panels, and are able to extract more power from the same surface area. This results in a smaller overall solar panel, which is ideal for applications where space is limited.
Simple, professional installation:
This particular model features the
junction box and cable on the rear side of the panel to create a completely level surface and professional finish after installation. Unlike other solar panels, the junction box on this solar panel is
a circular shape with
only one dual core cable (3m length) attached, allowing for simplified installation.
Please note: in order for this panel to be flush-mounted, a recess must be cut in to the roof/surface.
This solar panel has a unique black backing, making it ideal for discreet and aesthetically pleasing installation on dark coloured roofs, vehicles or mounting surfaces. Please note that this solar panel is not 'ultra jet-black' - the exact hue may vary marginally from panel to panel, depending on the batch of solar cells.
Anti-reflective textured surface:
The textured surface of this solar panel reduces the reflection of light whilst maximising the absorption of light from every possible angle. This ensures high performance in low light or cloudy conditions, or when the light falls at an angle (in the morning, evening, or winter).
Click on the Details and Specifications tab for more information about this product.
View attachment 276823View attachment 276824
View attachment 276825View attachment 276826View attachment 276828
View attachment 276830View attachment 276831
