Hi Guys,
Looking for a little help. I'm looking to install a CBE PC210 power Management kit in my T6. Here is the kit below:
CBE PC210 Complete Kit, CBE electircal, Caravan & Motorhome Electrical, CBE, Electrical Accessories - Grasshopper Leisure
I have a few concerns in relation to the charging part. Does anyone know if this kit is designed to charge both batteries or just the leasure battery?
The reason is ask is because I already have a Redarc battery to battery charger from Travel volts and don't want the CBE kit to interfere in any way with that.. My understanding is that the redarc b2b only works when the van is started therefore the CBE charger will not effect things as it only charges once hooked up to a 240v supply right?
I liked the idea of the CBE PC210 as it shows both B1 and B2 voltages. What I'm hoping is I don't have to disconnect the line to B1 if there is a possiabilty it effects the Redarc charger and then I lose the ability to see B1,s voltage.
Any advice would be greatly appreciated.
Paul
Paul
