H
Hi Farnorthsurfer,
I asked Renology the other day if it needed just ignition feed, as I thought their new charger might do the job with just ignition fed (not engine run), but I recieved a reply I didnt understand.... I replied with some more clarity but not got anything back yet...
"Thank you for contacting Renogy.
When you say engine run wire do you mean it will not be able to use a positive and negative cable from the starter to a DC-DC charger will need?
If so our DC-DC will not work without the direct connection to the battery. It will need the ignition on wire as well to turn the unit on when running the alternator.
If you have any further questions please let us know.
Thank you,
Matthew S."
Cheers John P.
Might indeed end up using ignition feed on the Renogy but I have a few weeks while Jerba stick the roof on so will try and bottom out the wiring.
Hi Farnorthsurfer,
Thank you,
Matthew S."
Cheers John P.
